How to upgrade to EXT/SS Brake Upgrade
by mikekey » Tue Oct 01, 2013 4:05 pm
Well if you want to go all crazy here:
ACDelco 172-2501 OE Service Front Brake Caliper - Qty 2
ACDelco 177-1050 OE Service Front Brake Rotor - Qty 2 - 15 inch rotors!!!!!
Front Brake Caliper Pin Kit - 25940448 - Qty 2
M14x2.0x40 Flange Bolts (Fastenal) - Qty 4
Problem is you're not going to fit these inside 17 inch rims, 18 inch, yes with proper back spacing.
by DirtyBacon04 » Tue Oct 01, 2013 4:46 pm
Y'all keep saying EXT/SS brakes and i'm assuming thats including a bigger rotor? If thats the case, i guess my 8.6" ext rear end was strange. it had the same size rotors as my 8". I just swapped my old ones over to the new axle.
by dvanbramer88 » Tue Oct 01, 2013 4:53 pm
DirtyBacon04 wrote:Y'all keep saying EXT/SS brakes and i'm assuming thats including a bigger rotor? If thats the case, i guess my 8.6" ext rear end was strange. it had the same size rotors as my 8". I just swapped my old ones over to the new axle.
That sounds right. The rears are in fact the same on EXT and SWB models across all submodels. The fronts are the ones that are different.
All SWB with a 4.2 I6 have the smaller front brakes.
All EXT have the bigger brakes.
All 2006+ SWB with the 5.3V8 have the bigger brakes.
by mikekey » Tue Oct 01, 2013 5:02 pm
Dave is right, like I stated in this article, the fronts are whats bigger. The rears are all the same. It is in fact a caliper-bracket, pad, rotor upgrade.
by Moots1288 » Tue Oct 01, 2013 5:24 pm
And really you can use the same pads if you'd wish to.
by ErikSS » Tue Oct 01, 2013 6:11 pm
Poor Moots. 16" wheels.
by Moots1288 » Tue Oct 01, 2013 6:12 pm
ErikSS wrote:Poor Moots. 16" wheels.
don't be a hater! Just needs a little grinding on the caliper.
by ErikSS » Tue Oct 01, 2013 6:15 pm
You might get away with that with worn pads. New pads in those calipers... I"ll have to see 16" wheels wrapped around them to believe it. haha. I only have about 0.25" clearence with my 17"
by Moots1288 » Tue Oct 01, 2013 6:26 pm
viewtopic.php?f=32&t=3678
Jcrayton did it with the correct back spacing
by ErikSS » Tue Oct 01, 2013 6:42 pm
That looks good. Maybe you could go that route. I wonder if the steel SS calipers are larger than the EXT calipers. I tried some 16" wheels and wasn't even close. Perhaps I didn't put in the effort to try all angles. I just went 17" wheels, solved all my problems. lol
by mikekey » Tue Oct 01, 2013 6:47 pm
Eric they're the same, yours just weigh more.
by Moots1288 » Tue Oct 01, 2013 6:47 pm
ErikSS wrote:That looks good. Maybe you could go that route. I wonder if the steel SS calipers are larger than the EXT calipers. I tried some 16" wheels and wasn't even close. Perhaps I didn't put in the effort to try all angles. I just went 17" wheels, solved all my problems. lol
Yea it's to late for 17s I think SS are slightly larger ill just probably end up going with EXT if it works
by ErikSS » Tue Oct 01, 2013 6:49 pm
I just know AJ had to grind the crap out of his calipers to run 15's on his 2005 LT. I know cause I did it. haha It was mostly his rear now that I think about it. Give her hell!
by Moots1288 » Tue Oct 01, 2013 6:53 pm
ErikSS wrote:I just know AJ had to grind the crap out of his calipers to run 15's on his 2005 LT. I know cause I did it. haha It was mostly his rear now that I think about it. Give her hell!
Haha only one way to find out!
by HARDTRAILZ » Mon Nov 25, 2013 1:21 am
Mike....your 1st post is right....be wary of Ebay.
SS front rotors wont fit EXT... something doesn't add up.
Searched for 06 SS and then cross checked with 06 ext v8.
Those should be same front rotors correct?
by jonbo2002 » Mon Nov 25, 2013 7:16 am
HARDTRAILZ wrote:Mike....your 1st post is right....be wary of Ebay.
Autozone and O'Reilly's shows different numbers too, so I just made sure to order the same year and trim I pulled it off. Didn't you get an invoice for the brackets I sent you? just make sure to order the brakes for that model.
jonbo2002
by HARDTRAILZ » Mon Nov 25, 2013 7:42 am
I believe SS and Ext should be same rotors.
Looking more for confirmation than knowing what to order.
Did find my pads are lifetime guarantee so only need rotors and I am good to go.
by jonbo2002 » Mon Nov 25, 2013 8:11 am
HARDTRAILZ wrote:I believe SS and Ext should be same rotors.
I sent you an 03 Envoy I would just order them here is autozone 03 Envoy 169.8mm inner 324.8mm outer vs. 08 SS 180mm inner 325mm outer
http://www.autozone.com/autozone/parts/ ... _2708_7514
http://www.autozone.com/autozone/parts/ ... 2993_2708_
jonbo2002
by HARDTRAILZ » Mon Nov 25, 2013 8:36 am
Won't use aitozone. One rotor is price of pair online.
by jonbo2002 » Mon Nov 25, 2013 8:51 am
oh I know that I was just showing the difference. and I know yours came off an 03 Envoy for sure. So I was just saying through the vendor on ebay you are ordering just make sure they list them for an 03 Envoy ext. I don't want you to end up with the wrong rotors
jonbo2002
