On Board Air
by Trail X » Sun Mar 20, 2011 7:49 pm
I finished up my OBA setup today. I used the tank in my bumper paired with my trusty old MV-50 superflow compressor. The combination produced a fairly inexpensive setup that should be pretty beefy, while occupying very little space.
The end result is a system that I can turn on anytime to charge the 4 gallon bumper tank with 110 psi of air. That air can be accessed from the quick-connect port on the rear bumper:
I'm using a 25 ft self-coiling hose with an ARB inflator with the system. The inflator allows me to read the tire pressure instantly upon letting go of the trigger. That alone should save a good portion of time.
The hose doesn't have much trouble reaching the front tires, however the reach to the front passenger tire is getting towards the max reach of the hose. I'm not sure if I could air up another vehicle without having them reposition.
Here's the MV-50 getting prepared in the shop. The MV-50 has 3 ports, all different sizes (dumb design if you ask me). The intake port is a 1/4" NPT (where the red muffler/filter attaches). The gauge port (where I now have the output) is 1/8" NPT, and the old output (now plugged) is an M12x1mm thread. I never did find a M12x1mm ANYTHING, so I ended up jamming a M12x1.25mm plug in and cut new threads. All I needed was for it to seal anyways, and it seems to have worked ok when paired with some Teflon tape.
Downstream of the compressor, there's a one-way valve. Compressor heads can leak back through the cylinder, so I mitigated that by adding the valve.
Below is the MV-50 installed in the passenger side storage compartment. I wanted it to be easily accessible if needed (like if it caught fire... :shock: ).
I have heard that the only downfall with some of these MV-50 compressors was that their heads can get too hot (I've never had an issue). To try to keep the head's temperatures down, I installed a small cooling fan that runs with the compressor cycle and helps keep airflow around the head and down towards the motor.
Next you can see the hose routing and wiring. The hose runs from the compressor through a gasketed bulkhead fitting and into the tank port. From the tank, it runs to an aluminum manifold block. On the block, there's an emergency blowoff valve (set to 165 psi) in case the compressor switches or relays fail. There's also a pressure sensitive switch, to control the compressor, and a manual bleedoff valve, which I probably don't need. The empty ports may be used for future projects, but for now are just plugged - I wanted to make sure the system had flexibility and room to add in the future. From there, the tubing runs to the quick connect on the outside of the bumper.
As the gauge shows: compressor on at 90 psi, and off at 110 psi. My guess is from 0 PSI, it takes maybe 2 minutes to blow the tank up to 110 psi (but I didn't time it). The MV-50 didn't seem to have any issues with the pressures.
I'm pretty happy with the result so far, but only time will tell if it holds up to vibrations and abuse.
by dirty anton » Sun Mar 20, 2011 8:03 pm
i know what we were both doin today! wierd! hey it looks great, its awesome how you integrated the bumper for air in your design! :cheers:
dirty anton
by DmccartneyFF2TB » Sun Mar 20, 2011 9:03 pm
That is awesome!!! I saw some where that a guy used his tubing from his roll cage as a air tank. Awesome work tho!
Dame
BDS,ROUGH COUNTRY,
Smitty Build XR-C8 Winch
www.wm4x4.com
DmccartneyFF2TB
by dlcsjoyce » Sun Mar 20, 2011 10:26 pm
Nice setup, looks great.
dlcsjoyce
by djthumper » Sun Mar 20, 2011 11:17 pm
Looks great! I hope it works out for your excursions.
by Diacom » Sun Mar 20, 2011 11:56 pm
That turned out great. Way to go for including the pop off as well.
by fishsticks » Mon Mar 21, 2011 2:34 am
Me likey! Will probably steal ideas from your build on this. :)
by navigator » Mon Mar 28, 2011 5:22 pm
James, I know this is a newby question but what is the advantage of the tank?
Wouldn't the pump itself work fine to pump up your tires after a trip?
Does the tank allow you to run some air tools like an impact etc?
by Trail X » Mon Mar 28, 2011 5:53 pm
Fine questions, not necessarily newbie level stuff.
navigator wrote:James, I know this is a newby question but what is the advantage of the tank?
The pump would work fine, and has for the past three years. However, the pump is annoying too. You have to raise the hood, set up the pump, go to the first tire and screw the air hose onto it, then go back and turn on the pump... then guess as to when the tire is at the correct pressure, go check the pressure with a gauge, re-hook up the compressor... adjust pressure. Then after you do that with all 4 tires, you have to pack up the rather warm compressor.
With the OBA, I just have to attach my air hose to the truck, go to the first tire, begin airing up (which is quicker due to the higher pressures), periodically let go of the fill lever to check the tire pressure, then pop it off and move on to the next tire. I won't have to touch the compressor, as it will automatically stop and start at the pre-set tank pressures. Should save a decent amount of time.
navigator wrote:Does the tank allow you to run some air tools like an impact etc?
It allows me to run air tools (for short periods of time due to the smallish tank), but also opens the door to stoking the fire with pressurized air, running an air locker, having an air horn, setting a tire bead, etc.
Since the tank was essentially free with the bumper (just a little extra design and fabrication time), and the setup saves me some cargo space, it seemed to be a no brainer.
by navigator » Tue Mar 29, 2011 8:30 am
very nice James, thanks for the response!
by Trail X » Tue Mar 29, 2011 9:01 am
No problem Chris.
As a quick update for anyone else wishing to do something like this... I went back through and hose-clamped all of my barb connections because a few of them developed leaks. For some reason I was initially under the impression that hose clamps were not necessary with a hose barb, but my experience says otherwise.
by dirty anton » Tue Mar 29, 2011 10:11 am
hey james i found a unloader on ebay ($6.00) and added it to the system and it helps alot,thanks again.you can hear it discharge upon startup, and since i upgraded to #12 wire and a short run to source there are not any
more issues with blowing the circuit. gave it a real workout the other day and no problems.
dirty anton
by Trail X » Tue Mar 29, 2011 2:10 pm
dirty anton wrote:hey james i found a unloader on ebay ($6.00) and added it to the system and it helps alot,thanks again.you can hear it discharge upon startup, and since i upgraded to #12 wire and a short run to source there are not any
Nice! I didn't use an unloader on mine, but it doesn't seem to be giving me any fuse blowing issues. I had considered it, but figured I'd only get it if needed. As of now, if I added one, I would have to reconfigure the output stack, as it'd be too long otherwise.
by Philberto » Wed Mar 30, 2011 4:51 pm
I've had issues with the fuse blowing when starting under load with the mv50, so I'd definitely look into it... link for the unloader?
by dirty anton » Wed Mar 30, 2011 11:02 pm
dirty anton
by fishsticks » Mon Apr 11, 2011 7:51 pm
Here's my take on OBA.
My trusty air compressor (<$50):
Not an MV50, but quite capable nonetheless.
Harbor Freight Cheapo Air Tank of YELLOW DEATH! ($24.95)
The guts of my trusty air compressor. Useless pressure gauge removed. I opted for copper line as it's easy to work with and the thing you see the compressor bolted into is the top of my stock airbox. My compressor's in my engine bay.
Tube routing...
The air tank fits up where the spare used to be, with just a little frame bending.
This valve lets me charge the tank from my home compressor if I wish. I've discovered it's unnecessary as the little 12v quickly fills the tank on it's own.
One air line out through the old tire winch hole. The other is under the hood next to my airbox.
The compressor is wired to the 30A trailer power lug on the underhood fuse block and operated via relay and a switch that I mounted under the light controls. The setup will happily fill the tank to 125psi and beyond (the relief valve kicks in then). There's a very slow leak back through the compressor head when the system is off, but it takes hours to lose pressure. I may put a one way valve in somewhere to help hold pressure.
With the compressor running, I can fill two of my 35's from 16psi to 30psi in about 3 minutes if the tank is full. Takes another 5 or so to get the tank back up over 100psi then I repeat the process.
I'll probably make a couple cosmetic changes in time, but for now it's fully functional, and built mostly out of things I already had cluttering up my garage.
by Trail X » Mon Apr 11, 2011 8:04 pm
Nice execution. What do you use as your fill valve?
by fishsticks » Mon Apr 11, 2011 8:38 pm
JamesDowning wrote:Nice execution. What do you use as your fill valve?
You mean the red guy in the pic above? That came on the tank.
Or am I failing to understand?
by chevycrew » Mon Apr 11, 2011 8:53 pm
I thought the same thing initially, but after reading it again, I think he is asking what you use to fill at the tires.
by fishsticks » Mon Apr 11, 2011 9:07 pm
Ah, it looks very similar to what JD is using... just not an ARB. Works reasonably as a deflator as well when not hooked up to air... but I think I want some auto deflators now.
