So I took a look at all the options available. I wanted something that wouldn't affect gas mileage too much, wasn't too heavy, yet was strong enough to handle a big load.
What I found was the Baja Rack.
I believe I have the first on a TB. So I figured I'd write up a short review.
It's a fully welded hollow carbon-steel tube construction. So it's light and will not rattle. Plus, the rack is powdercoated, and not painted, which should give it some added durability. I picked mine up from Sierra Expeditions (http://www.sierraexpeditions.com/).
Baja Rack offers two sizes (http://www.bajarack.com/products.html). The Mule, which I got, and the MegaMule, which I felt was just a bit too big for the TB.
The rear has two tabs for rear facing lights. I'll stick some lights in there eventually. I'm still looking for some small wide angle flood lights... any suggestions?
The front faring is also aluminum, and not a plastic sheet.
I used the stock crossbars for the rack, which actually worked very well with the Baja Rack mounting system.
Here are my Wedco gas cans in place, just so you get an idea. If any of you are wanting gas cans, the Wedco supply is running out... pick up some of the last ones at https://www.expeditionexchange.com/wedco/.
I'm also hoping to get a bike rack mounted up there. Although, I'm still unsure how that will all work out.
As always, I appreciate the feedback!
thieves
Still waiting on somebody to get a RTT and mount it on their roof so I can see how I'll do it myself, and unfortunately BajaRack's EXP rack is just too expensive for me to use that. Anything similar out there?
Congrats!! Now send some pics in to readers ride!.. I bet one of the mag's would do a write up on the TB/EV since it hasn't been covered much yet!
