I picked up a set of Pro Comp limiting straps to help with this. They are 26" straps that I mounted at the shock mounts. This limits the shocks to 26" of travel, which is what BDS states is the actual limit of the proper size 5500s and 9500s. This amount prevents the brake lines from being the limiting factor and keeps the spring much more secure. Now that I don't have to worry about a spring unseating... I can finally drive the truck a little more "spiritedly" to really test the ride without sway bars. Prior to straps, I have enjoyed the ride thus far.
Some measurements at rest and full extension.
