by Clank » Tue Aug 13, 2019 9:39 pm
Hey guys, recently my truck got stuck in park and after researching it seems that it's most likely my Shift interlock solenoid was bad. It still works but periodically gets stuck in park and I have to push the override button in to shift. I ordered a new one (ACDelco) and just put it in. It now shifts fine but for some reason the key will not turn all the way off in the ignition. It gets sorta stuck halfway between accessory mode and off and the dash/radio lights will sort of flicker. I've tried turning the wheel and putting my foot on the brake with no luck. If I plug the old solenoid in it works perfectly fine. At first I thought my ignition switch was bad but the fact that it fails only with the new solenoid leads me to believe I got a bad part. The part numbers are the exact same I even took the covers off the solenoids and the internals both look good. Just looking for opinions before I ship the part back for a refund
