Engine Temperature
by GiedriusZ » Mon May 28, 2018 7:40 am
How about your TB engine temperature? Now for the hot days I noticed that if you ride it is all ok temperature alwais up to 212F, but if you stay in place longer, the temperature rises above a 212F until 230F, and the air conditioner does not start to freeze, or barely freezes.
Giedrius, Lithuania
Chevy Trailblazer LTZ, 4x4
GiedriusZ
by Tricguy007 » Mon May 28, 2018 10:54 am
Sounds like either a thermostat or fan clutch is needed I just went and redid my entire cooling system thermostat, tempsensor, radiator, water pump,a/c condenser, and a new non electric fan clutch ,and hoses mine sits around 197-201 as we haven't hit the 110+ degree weather yet we are only in the low 100s in Phoenix
Tricguy007
Name: grant Huskelhus
by Trail X » Thu May 31, 2018 1:22 pm
Clean your radiator, and possibly install a 180 degree thermostat.
by bartonmd » Thu May 31, 2018 4:15 pm
Clean the radiator and fix the fan clutch and/or water pump. Having said that, here's the fan % vs engine temp, and even at 230, the fan is only 50% engaged.
by GiedriusZ » Tue Jun 05, 2018 11:14 am
I faund that cooling fun cluth is not working. but it's not clear why.I have not yet determined what is wrong. Is the fan clutch defective, or a temperature sensor. Maybe someone has changed a fan with a clutch to an electric fan. I would prefer to pass one or two electric fans.
like this https://www.carbuildersolutions.com/de/ ... rved-blade
Giedrius, Lithuania
GiedriusZ
by Trail X » Tue Jun 05, 2018 8:42 pm
viewtopic.php?f=27&t=3955. Time to get your reading glasses and a cup of coffee... :coffee:
