clunk when shifting from neutral
by stastyle » Mon Oct 10, 2016 5:53 pm
Hey guys,
I have a 07 TB LT with 150k miles on it.
Lately i noticed that my transmission makes a noticeable clunk (only one) when shifting from neutral to drive, reverse or park. sometimes it does the same clunk sound when starting the car - right after the car starts (again - only one clunk). What's weird is that it happens sometimes, and sometimes does not, and it's not related to ambient or TB temperature - so i ruled out engine/transmission mounts (plus my mechanic said they are fine).
I changed the oil and filter to the original AC Delco Dexron 6 about 3000 miles ago. Oil level is right where it should be.
Should I be worried ? i couldn't find any related topics regarding this issue.
Any ideas ?
Thanks,
Stas.
stastyle
by Wahugg » Mon Oct 10, 2016 6:54 pm
Sounds like it's just slop in the driveline being taken up as the transmission tensions up everything.
It also could be U-joints starting to go bad and introducing extra slop but there should be other symptoms if they were that worn.
Cheers,
Wahugg
Wahugg
by mason10198 » Mon Oct 10, 2016 7:32 pm
I've got the same exact thing with mine, it's just wear and tear on the driveline components and sloppiness tightening up when you engage it.
Sent from my SAMSUNG-SM-G870A using Tapatalk
by stastyle » Tue Oct 11, 2016 10:16 am
So nothing to worry about ?
stastyle
by mason10198 » Tue Oct 11, 2016 4:15 pm
Shouldn't be. Now if the clanking continues while you dive, that might be something to consider checking out lol
