Oil Pressure Gauge
by mason10198 » Sat Jan 09, 2016 4:59 pm
I had this problem when I first bought the TB but it went away. Now, a year later, it's popping up again.
Only happens when idling in park after driving for a while. I'm guessing it's just a pressure switch that needs to be replaced. Unless someone else thinks it's a instrument cluster problem or something.
https://drive.google.com/file/d/0BwtnQ1 ... cslist_api
Sent from Tapatalk
by KingBird » Sat Jan 09, 2016 5:13 pm
Yeah, that's definitely your sensor. It's right above the oil filter. Could be a bad connection, but it's usually a faulty sensor.
KingBird
by TBYODA » Sun Jan 10, 2016 3:26 am
Btw the oil pressure gauge is a lie. IIRC the gauge get signal from the bcm or PCM to approximate the oil pressure.
by KingBird » Sun Jan 10, 2016 10:59 am
Yeah, all the sensor does is say whether or not it has pressure, any fluctuation in the needle movement is the computer trying to make you think everything is OK.
KingBird
by mason10198 » Sun Jan 10, 2016 12:38 pm
Yeah, Ive known. that's why I call that sensor an idiot switch lol
Sent from Tapatalk
by DirtyBacon04 » Sun Jan 10, 2016 9:30 pm
yup. happened to me not long ago.
easy repair and a $40 part
by Ole Blue » Mon Jan 11, 2016 3:25 pm
+1 for the sensor
Ole Blue
