SOLVED! - Clunking noise from ?front?
by onebigburb » Thu Jul 09, 2015 10:15 pm
Okay so my sas parts aren't here yet so I decided to put tb back on the road. So i'm back to the first problem that kind of started this whole sas. This started months ago. After up tooling around in woods one night on drive home I noticed clunking in front end. Over time it got louder (like weeks or months of time). I have tried to find source and can not locate it. Jacked up inspected found no play in wheel bearings. I noticed front diff. was toast so I have pulled cv shafts, left stubs in to hold wheel bearing assembly together. Pulled front drive line. Thought it was on passenger side so changed wheel bearing. Removed sway bar. Nothing has changed the noise is still there. Checked rear driveline for u-joint play. Yanked t-case around to see if it had bad mount. The noise is straight forward clunk under acceleration it gets louder. Feels like its under front end somewhere. almost like having flat but has a definite metal solid feel. Any thoughts?
onebigburb
by AA1PR » Thu Jul 09, 2015 11:16 pm
can you mount a gopro under there ?
I'm not familiar with your rig but if it has struts look at the top strut plate
1966 Stevens M416 trailer too
AA1PR
by onebigburb » Fri Jul 10, 2015 1:53 am
I have been thinking about buying go pro for this/these scenario's for a while. yes factory suspension still. It sounds like rotational mass. How would the strut plate move to make that sound? new to the strut scene.
onebigburb
by Jrgunn5150 » Fri Jul 10, 2015 10:29 pm
Upper ball joints tend to clunk when they are bad, have you checked them?
by Trail X » Mon Jul 13, 2015 5:33 pm
Can you describe the clunk a little better? Is it on bumps or dips or when you're topping out or every time the tire spins? That can at least put us in the right location of the rig.
by TBYODA » Fri Jul 17, 2015 4:47 pm
Cody maybe you have a loose outer TRE, like I had. See video below.
https://drive.google.com/open?id=0B4qNs ... Xc2MVlWbVk
by onebigburb » Sun Jul 19, 2015 4:54 pm
sorry guys i've been slammed lately. So I gave up and sent it to dealer, came back saying the driver hub was bad which I didn't belive. So I changed it out. A guess what it was my problem. Soooo wierd cause it came threw passenger floor board clear as day. I guess mental note to guys just because it appears one way doesn't mean thats it. Thanks guys
onebigburb
by ErikSS » Mon Jul 20, 2015 4:50 pm
I'm glad you have it resolved.
