muffled sound when accelerating
by jak3on » Thu Jun 25, 2015 11:00 am
need help figuring this out. started the other morning out of nowhere when i accelerate it sounds muffled but only when i accelerate. when i let off the gas and coast its fine no noise. im also getting what i think is a loss of power and terrible gas mileage. averaging around 10-12mpg here lately. ive checked the o2 sensors, cleaned air filter, exhaust doesnt appear to be leaking and no odor from exhaust any ideas?
jak3on
by Trail X » Thu Jun 25, 2015 12:20 pm
Getting a muffled exhaust noise on acceleration sounds normal to me. You'll have to be more descriptive, otherwise it just sounds like you're talking about normal engine exhaust noise.
by jak3on » Thu Jun 25, 2015 12:31 pm
okay its almost as if its struggling to accelerate and the sound is kind of hard to explain almost like a diesel or something. ive got a video i recorded with the sound in it. ive gotta push the pedal half way to the floor to reach 25mph and ive basically got to floor it to reach 60mph which is what most of my drive home from work is.
jak3on
by HARDTRAILZ » Thu Jun 25, 2015 1:20 pm
Sounds like a clogged cat.
by HeavyChevy4200 » Thu Jun 25, 2015 1:23 pm
Is the cat getting extremely hot? 60mph pushed to the floor would make it glow. The rear resonator could be coming apart and may have clogged up the tail pipe. Any string or fiberglass poking out the back?
HeavyChevy4200
by jak3on » Thu Jun 25, 2015 1:51 pm
no string or fiberglass. i will hafta check cat after i drive home after work to see if its hot. is there any other way to check to see if its the catalytic converter?
jak3on
by Eredin » Thu Jun 25, 2015 7:13 pm
Clogged converter would definitely cause that issue. As Andy mentioned, it'll start baking if it doesn't pass enough exhaust through.
2005 Chevrolet Trailblazer LT
2012 Chevrolet Cruze LT
Eredin
by jak3on » Fri Jun 26, 2015 2:51 pm
I checked it yesterday it wasn't cherry red but it was definitely throwing some heat
jak3on
by jak3on » Fri Jul 17, 2015 1:50 pm
Update. Changed converter but that want it. Also I'm only getting 12mpg and have a cv boot throwing geese now
jak3on
