lft kit confusion
by HawkTown28 » Fri Jun 12, 2015 12:59 am
So I recently received marks 2.5 inch lift kit in the mail. I also go his wheel spacers, bilstein struts, and bds 5500 rear shocks. I though I had it all figured out but I cannot wrap my head around what to do with all of the washers in the front struts. So my new struts came with a large black "cupped" washer. With marks lift kit I was supplied with 2 small silver washers. Now in the directions it sounds like I am supposed to replace the large black washer that came with my struts with the small one supplied with the lift kit. This makes sense to me to clear the spacer, but the washers I got in the lift kit are much much smaller than the ones that came with the strut, and it just seems like to me that if I replace them, the smaller washers will destroy the bottom of the bushing on my strut mount. In the picture of marks kit, 2 gold washers are pictured, which seem to be smaller than the black washer that cam with my new struts, but decently larger than the washers I was supplied in my lift kit. If anyone can help I'd appreciate it since I plan on installing it tomorrow. Thanks.
HawkTown28
by Trail X » Fri Jun 12, 2015 9:41 am
You got any pictures of the parts? Your bushing washers should be about the same diameter as your bushings. The lower washer can be somewhat smaller, but the upper one must be about the same diameter or it will start to pull through your bushing.
by markmc » Fri Jun 12, 2015 12:16 pm
Use the washers that came with the kit.
Or you can grind the washers that came with the struts to fit through the lift casting.
markmc
Rank: Mall Rated
