The 4wd stopped working a while back. I ran through the flow chart for the 4wd. Passenger side front tire up in 4hi, tire spun freely, no driveshaft spin. Both front tires up in 4hi, passenger tire turns without turning the driver side or drive shaft. Diagnosis front disconnect, right?
I replaced the disconnect and installed a new actuator. The disconnect had no splines left on the shift collar. It was toast. While I was in there, I swapped out both cvs, and a leaking front diff seal. I got everything back together and hit a dirt road around the corner, and the front still wouldn't engage! I still have low range, but without the front axle.
I can hear both motors working. I run through the flow chart again. Right front tire up in 4hi, tire spins freely, driveshaft spins also! Both front tires up in 4hi, the passenger side tire turns freely, turns the driver side tire(opposite direction), and driveshaft. Right fornt tire up in 4lo, tire tuns with resistance. Well I fixed the disconnect.
The next day when I started the truck, the 4wd switch on the dash said the t-case was in neutral. It wasn't I could pull forward and back. I put the tranny in neutral and heard the encoder motor turn. The light over 2hi light up (it was not flashing before) and the truck drove fine. This happens every time I mess with the 4wd switch now. The day after trying the switch (not the next engine start) it either says it's in neutral and/ or trying to shift to a4wd. Sometimes all the lights on the 4wd switch flash after start up, until I shift the tranny to neutral. No matter what the dash switch says the truck will drive in 2wd.
Any idea what direction I should go? Start throwing parts at it, (4wd switch, TCCM, encoder motor) or is my t-case done?
