Wheels won't balance
by navigator » Thu Aug 07, 2014 8:12 am
I would also be curious if those balancing beads might help.
I've never used them but I don't recall them being that expensive.
by ErikSS » Thu Aug 07, 2014 8:15 am
Maybe they need to go back on Craigslist.
by Moots1288 » Thu Aug 07, 2014 8:26 am
navigator wrote:I would also be curious if those balancing beads might help.
I don't know how balancing beads would work will a broken belt in the tire.
by navigator » Thu Aug 07, 2014 9:42 am
yeah, I thought about that. I was curious though with them being dynamic if they would still help.
by Trail X » Thu Aug 07, 2014 6:20 pm
Assuming they are new, I'd contact the manufacturer.
by Bacnbit » Fri Aug 08, 2014 9:15 am
Take them to a shop that has a "road force balancer" not a standard balancer and they will be able to tell you specifically what is wrong with the tire or wheel. Within minutes. Then the Dicking around is done.
Bacnbit
by TBYODA » Fri Aug 08, 2014 10:10 am
Cut your losses and put them back on CL.
by AA1PR » Fri Nov 07, 2014 9:39 pm
in the shop we marked the tire & rim with yellow paint from a parts marker
break down the rim & tire
rotate the tire 180 degree & remount
rubber density, steel/aluminum density varies
& you should never have more than 2ounces of weight on any rim, if you do ask them to do this & it will improve
thats my experience with such in the shops
1966 Stevens M416 trailer too
AA1PR
