How bad are these ..?
by Chango » Sat Apr 26, 2014 10:01 pm
Took apart the 4.10 front diff I purchased, and found one of the bearings looks like it has some pitting. Is this a big deal? All the others look fine and roll nice....Image
Chango
by DustinC1989 » Sat Apr 26, 2014 10:31 pm
I would replace it regardless
DustinC1989
by bartonmd » Sat Apr 26, 2014 10:39 pm
That looks to me like it's goop that would wipe off of the rollers. I assume you've already sprayed it all with lots of carb/brake cleaner and a brush, or put it in a parts washer before you took the picture?
by Aries » Sat Apr 26, 2014 10:41 pm
Chango wrote:one of the bearings looks like it has some pitting. Is this a big deal?
Yes! Replace it!
Aries
by Chango » Sat Apr 26, 2014 10:49 pm
bartonmd wrote:That looks to me like it's goop that would wipe off of the rollers. I assume you've already sprayed it all with lots of carb/brake cleaner and a brush, or put it in a parts washer before you took the picture?
Yes I did clean it first. You can feel/ see the pitting. Its just on one bearing, and just on about 5 or 6 rollers.
Chango
by Chango » Sat Apr 26, 2014 10:54 pm
I'll check the others more carefully tomorrow...and order a new bearing for this one
Chango
by bartonmd » Sat Apr 26, 2014 11:23 pm
OK, then yes, it is a problem.
by Chango » Sun Apr 27, 2014 12:44 pm
Anyone have any tips on how to get the races out? Do the come out from the seal side? Do ya have to take the other bearings out first? Image
Chango
by Bacnbit » Mon Apr 28, 2014 12:16 pm
They are toast!! Replace them all and think hard about any other bearings in the unit due to metal in the oil and running through the bearings. Just saying. I know its a pain but I would rebuild all.
Bacnbit
by Trail X » Mon Apr 28, 2014 12:33 pm
My understanding is that you unscrew the adjuster, and the bearing race will come out the same side as the adjuster.
by Chango » Mon Apr 28, 2014 4:11 pm
Trail X wrote:My understanding is that you unscrew the adjuster, and the bearing race will come out the same side as the adjuster.
Thanks. Guess its a total rebuild for me ...:cry:
Chango
by v7guy » Mon Apr 28, 2014 10:44 pm
Yeah, looking at that race, it needs replaced. When you replace a bearing you need to replace it's race as well.
Probably would be best to get the full rebuild kit.
The side bearings and races are a breeze, the pinion races and bearings are a little tougher. I removed mine with a prybar and a punch.
Outside of an inch pound torque wrench there really ain't too many special tools involved, just takes patience.
by Aries » Tue Apr 29, 2014 3:22 am
Chango wrote:Anyone have any tips on how to get the races out? Do the come out from the seal side? Do ya have to take the other bearings out first?
The race just kinda floats, remove the adjuster and tap it out towards the inside of the housing. Some times they just fall out. I've done a couple front diff rebuilds, post any question you may have.
Aries
by Chango » Tue Apr 29, 2014 8:25 am
Thanks!...I'm sure I will be sending you some Pm's.
Chango
by Aries » Tue Apr 29, 2014 11:38 am
Chango wrote:Thanks!...I'm sure I will be sending you some Pm's.
This may help also http://gmtnation.com/forums/topic/361-need-service-manuals-get-them-here/?p=5515
The R & L bearing adjusters along with some other tools mentioned in the service manual I got off ebay, all for less then $50 shipped
Aries
