no 4x4, no lights, no nothin
by tarsh » Wed Mar 05, 2014 8:08 pm
Same problem as rosier1 had except I have the lights that turn on with ignition, after that there's nothing. Engaged the 4x4 goin 10mph or so then felt a slight jerk and heard a continuous clicking from what sounded like the t-case. Tryed to put it back in 2hi and nothing and the clicking went away.when I got home I Tryed the neutral switch,put it in reverse,drive nothing. It said it was in 4hi but it was not. Your brains are better than nine at this So any help would be great. I have yet to check fuses and I don't have a service 4x4 light.
Thanks
Take the path less traveled
tarsh
Name: Nathan Schroeder
by Edubarajas » Wed Mar 05, 2014 9:44 pm
Have you pulled out your actuator that engages you 4X4
Edubarajas
by tarsh » Wed Mar 05, 2014 9:56 pm
So mad right now! I just went out and Tryed it. It works. I was so flippen madd! Must be a TB thing :work: :wallbash: :oops: :facepalm:
tarsh
by TBYODA » Wed Mar 05, 2014 10:42 pm
Could be the switch try moving it thought the 2hi <--> 4lo about 100 times with the TB off.
by Edubarajas » Thu Mar 06, 2014 12:03 am
That's happened to me I just turn the ignition off then on and it works. Or sometimes it stays on neutral it happens
Edubarajas
by tarsh » Thu Mar 06, 2014 12:07 am
Idk. I'm just glad it fixed it's self . Not sure what the clicking was but it didn't sound real good
tarsh
