head gasket!!!
by mikekey » Thu Nov 21, 2013 5:01 pm
navigator wrote:I seem to remember several years ago there being mention of issues with aluminum heads but none recently.
I guess I should preface that with, I've heard the same thing, but specifically recall it was with heads made by Honda cheap Chinese metals.
by navigator » Thu Nov 21, 2013 5:07 pm
I did a little reading, seems that we now have better electronics to know when an engine is hot and then limit it and that has helped reduce issues. There was some mention of temp gauge reading coolant temps vs engine temp, if coolant was non-existent (boil over etc) that the temp would drop when in reality it was really high.
by Trail X » Thu Nov 21, 2013 5:10 pm
Just curious, how did you determine that you indeed have a head gasket leak? Did you do a compression test? Are you positive that it isn't a piston ring?
by Moots1288 » Thu Nov 21, 2013 5:15 pm
I know of a good amount of warped aluminum blocks then they switched to cast
by mikekey » Thu Nov 21, 2013 5:37 pm
Moots1288 wrote:I know of a good amount of warped aluminum blocks then they switched to cast
?? Huh ?? Who ?? Surely not GM.
by TBYODA » Thu Nov 21, 2013 5:45 pm
Is that not with cast block and aluminum head, heats/cools at different rates?
by mikekey » Thu Nov 21, 2013 6:11 pm
What would that have to do with a warped block, he said warped blocks.
by Moots1288 » Thu Nov 21, 2013 7:50 pm
you want there phone numbers? Hold on..
by mikekey » Thu Nov 21, 2013 8:12 pm
I think you mean heads Matt, not blocks. Blocks usually crack, not warp.
by Spot u 3 » Thu Nov 21, 2013 11:44 pm
I started getting the milky white oil cap. Secondly, I was losing coolant. I did a coolant pressure test and found I have a leaky thermostat housing. When I took of my resonator I had a bunch of the same stuff I seen under the oil cap. I tried to post a pic but it keeps saying file is too large. My dipstick and oil seems fine, but I'm going to drain it and take it in for analysis. The stuff I found in my resonator looks like red clay.......here's the pic http://i853.photobucket.com/albums/ab10 ... 043b6c.jpg
Spot u 3
by Spot u 3 » Thu Nov 21, 2013 11:54 pm
Spot u 3
by dvanbramer88 » Thu Nov 21, 2013 11:59 pm
The red clay stuff is broken down dex-cool. We ran into a ton of that stuff when we had to put a new head/gasket on our Jeep. We also got the milky build up on the oil cap.
by dvanbramer88 » Fri Nov 22, 2013 12:02 am
Spot u 3 wrote:Awwwww I found a TSB from GM!! http://ww2.justanswer.com/uploads/Blueg ... ss_5.3.pdf
Does your TB have the 5.3 V8?
by Spot u 3 » Fri Nov 22, 2013 12:10 am
I6
Spot u 3
by RyansTBLS » Fri Nov 22, 2013 12:13 am
The report was for 4.8 & 5.3 V8s. Thanks for giving me a heartattack! :slap: Thought I had to go inspect the truck... :facepalm:
RyansTBLS
by navigator » Fri Nov 22, 2013 8:52 am
how does it run?
You can get a compression tester from HF for about $25 if I remember correctly.
by Trail X » Fri Nov 22, 2013 10:58 am
Yeah, it's not much, and would be worth checking before going through the work and expense of changing the head gasket.
But if it's a coolant to oil leak, then the compression tester wouldn't be able to identify a problem.
by Spot u 3 » Fri Nov 22, 2013 12:42 pm
I spoke with a GM buddy of mine and he said the bulletin I found was outdated. Some trailblazers had the castech head and is prone to head leaks, but a select few. It doesn't overheat so I cleaned everything out of the resonator and the throttle body. I have 145,000 miles so I guess I will drive it until it blows up!!!!
Spot u 3
by navigator » Fri Nov 22, 2013 2:29 pm
I know you mentioned you are losing coolant, are you "gaining" oil?
Is your oil on your dipstick milky?
You mentioned a little milky oil on your oil cap but I have read that could be from short trips, condensation not fully cooking off. I see that a little in my 5.3 suburban because my wife does a lot of short trips to school.
how is performance? any codes?
by v7guy » Mon Nov 25, 2013 1:03 am
I'm pretty troubled by a lot of the info in this thread. It's like a big beacon of WTF flashing in our otherwise relatively calm sea of good tech, self correction, and healthy debate and banter.
As mentioned, the milky oil could just be general condensation. The stuff in the tail pipe could just be an accumulation of orange clay dust. With that said I think it's probably a blown/seeping head gasket... the previous explanations are probably right, but I've been wrong before.
First step is to replace the thermostat housing that is leaking, then recheck the pressure on the coolant system. If you're still getting a leak the coolant is going somewhere and it's probably the head gasket given the info we have. Secondly, do a compression test, you say you've got some orange deposits in the resonator that's commonly associated with dexcool being burned and shoved out the exhaust (per dave? lol) and you also have milky oil. All signs point to oil and coolant mixing. One of those cylinders should also show a leak like the coolant system did. If you determine that it's the head gasket, I'd just replace it.
Concearning motor replacement. With any motor you get you run the real chance that it was abused/neglected. Unless you open it up and at least check the bearings with plasti gauge, verify the valves seal and the motor is in generally good shape you're tossing the dice. I've tossed motors in and things were great, and I've tossed motors in that spun bearings 3 months later. If you're going to replace a motor and not check everything out, don't be surprised when it self destructs. You only have yourself to blame. You decided to roll the dice. With that said, if you're going to tear down a motor to check the bearings and make sure everything seals and is clean, then you've already spent more than what it would cost to swap out the ole head gasket. As MikeKey likes to occasionally remind us, sometimes the solution that is the cheapest isn't really the cheapest in the long run. We benefit from spending a little bit more up front and saving a lot in the months and years following.
I can say that if the oil and coolant are mixing you likely have weeks or a few months left on the motor. The coolant leaking into the motor will fairly quickly destroy the bearings on the crank and rods and you'll get a hell of a knock out of nowhere that rapidly gets worse and worse over the course of a few dozen miles. I've experienced this first hand in my younger years and with friends. So know that I speak from experience.
In addition if you let it overheat... and realize that the temp gauge on your dash is basically nothing more than an idiot light. You're likely not even going to be able to salvage the motor because of a cracked or massively warped head in addition to the crank and/or rods kissing the bearings. At that point even 2500 for a used motor is worth it, but I would still suggest at least using some plasti gauge to check it all out first so that you don't risk having to go through all this again.
Speaking of warped heads (and blocks)... what the flying frack is going on here?
I'm going to go out on a limb here and say that engine blocks don't generally warp even if they're aluminum. After reading that comment I spent a few days searching out on the web (because I thought maybe I've missed something big all these years) and I couldn't find a single example where that was the problem be it from toyota, honda, GM, ford etc. Some questions started out that way and then it turned out the head was warped, but c'mon guys. This should have been beat down and dispelled the minute it was mentioned. If we're talking about core shift, ok, I can get on board with that. Modern engines don't seem to have a problem with it though. We're talking BIG power to get there. Older small block chevys need 1500hp or so to see core shift unfilled, the LT1 in my firebird even if it's unfilled needs about 1200hp to experience some core shift. These are all old cast iron blocks though. If you want to go to aluminum, you can look at the LS family of engines that pretty commonly see 1000hp+ with no issues at all, they don't even need a partial fill. Then just in case you want to have more power in a dead nuts reliable package GM and a few others offers a cast iron block to get you even more cubes and hp ranges that are undriveable on the street. Even Toyota with their long thin JZ series engines (1 and 2) didn't have any real issue with their aluminum blocks warping. Don't thin for a second I don't recognize the difference in block archetecture and the impact that has, comparing the old SBC to the LS family isn't even really fair, but it's the comparison we have to work with.
Keep in mind that there are some really strong indications that GM had every intention of throwing a turbo on these engines and the idea that a little overheating would cause the block to warp is fracking rediculous. Don't get me started when big money is involved where top fuel is running cast iron blocks to channel 8000+hp or where F1 is using the aluminum block as a stressed member that sees 5gs from the suspension and has the entire motor weighing 210lbs that displaces 214ci and makes 720hp at 18000rpm.
Yes I can provide multiple links to back up all of these claims. Most will come from LS1 tech and the LT1 comments will come from when george baxter was pushing the LT1 and then from the guys over on LT1tech. SBC chevy examples can be found everywhere. Toyota references are easily found on the supra forums and the Ford proof comes from the ford guys trying to show their shit isn't garbage. The guys that have been in this game for a while know exactly what I'm talking about.
Speaking of warped aluminum heads, yes, it does happen. Yes they can be resurfaced and made alright. The long head of an inline 6 motor is more apt to warp than a v6 or a v8, unfortunately it's just the nature of the beast. Some motors are more prone to it than others. Some motors are even a replace the head and forget about it type of deal. I havent' seen that our motor is a problem motor though.
If you're going to just let it ride get the money for a new motor ready or get a motor ready to swap in and know it's in the near future.
