Ok, recently after I changed my brakes and rotated my tires I've developed a small vibration in my truck which also has a resonating thumping/humming sound. It sounds like your driving on a flat spotted tire, and appears to be coming from the right front side. ( different pitch than normal with my mud tires)
Now my tires were fine and no balance issues prior to doing all this, no weights are missing. My new rotors look like they were balanced because one was notched in the vein area and doubt my rotors would be causing the issue. Both front wheel bearings were replaced in March with new delco's under warranty, however the right side did spew grease out of the rear of the hub seal not a whole lot but a good uniform ring. I brought it back and dealer said its normal, the factory over packs them. ( I thought it was BS, but they won't warranty it without bringing my truck in. Well, the wont anyways seeing the lift and hub adapters.) Despite that, neither of them have any play. So for now I ruled them out.
I looked at the disconnect, I had quite a but of play where the tripod connected into it and figured since mines never been touched I probably burned through a needle bearing. Well upon further investigation, only the outer seal were showing signs of wear...all internal bearings were good and lubed.
So I replaced the outer seal only and tossed in an AWD sleeve since I was in there and re packed with fresh grease.
Also inspected the CV shaft, the outer joint seemed to be really stiff and possibly under lubed so I replaced that with a new shaft as well since there is 90k on them.
Also my outer and inner tie rods on the right side had a small amount of play so I installed new ones as well and just had an alignment done.
Well the damn noise is still there along with the vibrations, only things left I can think of are... Upper and lower ball joints are still OE's, the upper was sorta loose bottom as well... But would these cause the humming noise or should I just bite the bullet and buy a timken?
Guess I'm just looking for opinions here, I'm headed to Maryland to work for the week so I won't be able to play till next weekend with it.
