Anyone know if there is a thread for Airbag Light Codes?
by Blazintrails03 » Wed Jun 26, 2013 8:19 am
I've looked around but haven't really found much info. I have the code just wondering if someone can point me to the spoon instead of picking it up themselves haha. Thanks for any help. And yes I'm gonna put this on gmtnation as well.
Blazintrails03
by navigator » Wed Jun 26, 2013 8:22 am
what is the code?
by Blazintrails03 » Wed Jun 26, 2013 11:23 am
Boo44
Someone on GMT told me about the service manual thread http://gmtnation.com/f23/need-service-m ... -here-371/ gonna check that out later
Blazintrails03
by navigator » Wed Jun 26, 2013 11:28 am
by navigator » Wed Jun 26, 2013 11:30 am
by navigator » Wed Jun 26, 2013 11:32 am
there are 4 threads on trailvoy pertaining to that code, just make sure to report back here what you find!
by WaltV » Mon Oct 07, 2013 12:18 am
DTC B0026 (stage 1) or B0044 (stage 2) will set when one of the following conditions occurs:
The steering wheel module high circuit is less than 2.4 volts and the steering wheel module deployment loop is more than 6 ohms for 500 milliseconds.
The steering wheel module deployment loop resistance is more than 4.8 ohms for 500 milliseconds.
There could be multiple root causes. You most likely have high resistance in the stage 2 deployment loop. If you're lucky reseating related connectors might take care of it. More realistically, you probably have a bad SIR Coil. You'll have to remove the steering wheel airbag to test it.
WaltV
