Bad vibration in 4x4 under acceleration
by 2003tv » Tue Jan 15, 2013 7:29 am
Did a search and couldnt find a solution to this problem that others have also had. In 2wd everything is smooth and vibration free. in 4hi there was a bad shake. My first thought as bad as it was that it was a wheel loose. ( i think coming more from the right front ) when accelerating( not hammering on it just normal picking up speed, then goes away when i let up or am just cruising. Changed both cvs today thinking that was the issue ( right one was pretty bad. But to my disappointment the shake is still there, slightly better but still there.New lower ball joint on both side Both wheel barrings , outer tie rods , struts and springs have all been replaced over the last six months so i have ruled them out. any help on this would be greatly appreciated
2003tv
by NC_IslandRunner » Tue Jan 15, 2013 8:02 am
Not sure but why would you be cruising in 4X4?
by 2003tv » Tue Jan 15, 2013 8:59 am
Iam not bad choice of words do know of something else i could look at
2003tv
by bartonmd » Tue Jan 15, 2013 9:10 am
Hmmm... Since it never happens in 2WD, I would hazard a guess that it's something that's moving only when you're in 4WD. That's really only the output of the T-case, the front prop shaft, and the carrier/ring/pinion in the front diff. Could be the loaded thing on the CV shafts, I guess, but if you've already replaced them and it still does it, that kills that as a thought. Maybe a bad front prop shaft U-joint or tri-pot (or whatever the CV is at the T-case). You might get under there when it's parked and see if there is any real side-to-side play in the front prop shaft?
by 2003tv » Tue Jan 15, 2013 9:29 am
Would you have any pictures so i know what iam looking for
Lee
2003tv
by HARDTRAILZ » Tue Jan 15, 2013 9:31 am
You need an alignment...
by DirtyBacon04 » Tue Jan 15, 2013 9:40 am
HARDTRAILZ wrote:You need an alignment...
This
Also, might wanna crack open your disco and take a gander + re-grease.
Sergeant, USMC
by bartonmd » Tue Jan 15, 2013 9:41 am
2003tv wrote:Would you have any pictures so i know what iam looking for
Lee
It's the drive shaft that goes from the transfer case to the front differential. It's right next to the driver's side of the transmission.
As Kyle said, I guess I had assumed that it otherwise was aligned and good to go. If your front prop shaft joints are fine (free 2 minute check), alignment is where I'd personally go.
by Conner299 » Tue Jan 15, 2013 9:52 am
If its coming from the right side, and happens under load, all I've read makes it sound like the 4WD disconnect... I agree with DirtyBacon. Pop that puppy apart and check it out.
Conner299
by 2003tv » Tue Jan 15, 2013 9:55 am
I took apart the 4WD disconnect allredy and put new grease in it
2003tv
by Conner299 » Tue Jan 15, 2013 10:04 am
2003tv wrote:I took apart the 4WD disconnect allredy and put new grease in it
Assuming all the internals(bearings, seals, gears, etc.) were still in good condition, I'm stymied.
Conner299
by HARDTRAILZ » Tue Jan 15, 2013 10:12 am
HAVE YOU GOT AN ALIGNMENT SINCE YOU DID ALL THE WORK IN PAST 6 MONTHS?????????????
by 2003tv » Tue Jan 15, 2013 1:09 pm
Yes I got a alignment about a four weeks a-go after i put hte lower control armes in
2003tv
by HARDTRAILZ » Tue Jan 15, 2013 1:25 pm
Any issues with it before then? I had exact same symptoms and a good alignment cured it.
by DirtyBacon04 » Tue Jan 15, 2013 3:52 pm
Make sure your axle nuts are tq'd down. (can you tell I'm running out of ideas?)
Sergeant, USMC
by plaen » Tue Jan 15, 2013 4:23 pm
I also have this same problem, had it aligned 6 different times, wheels balanced 10, 2 sets of cv shafts, regreased the disconnect, changed the u-joint on the front prop shaft.
Only thing I haven't done is pull the diff and check its internals, has the normal amount of play in the front prop shaft, so I gave up on it a few months back, since it only happens to me from 0 to 25-30 mph, then goes away, which I'll never be going that fast on trails, and its not daily driven.
plaen
by Kuchar09 » Tue Jan 15, 2013 6:48 pm
I also have the same issue up to about 30 mph. Had this issue ever since I had all new cv's and ball joints put in a few years back by the dealer after I lifted my TB.
I have also had it aligned multiple times, wheels balanced, multiple sets of cv shafts and also re-greased the disconnect last summer and everything looked good.
So obviously would love to hear the solution to this issue, keep us updated!
Kuchar09
by Opeth » Tue Jan 15, 2013 7:58 pm
I have the same issue as well, I get a wobble in my front end while in 4x4 going 25-30mph under acceleration and then goes away. When swapping wheel bearings out on Saturday I did notice while free turning the shaft it didn't exactly rotate centered in the inner tripod. I could see the shaft moving almost up and down slightly, but my suspension was also at full droop.
I'm still on OEM cv's since they haven't tore or anything but also lifted 3", and have had an alignment. I figured it was my cv's being in a new position but haven't had the funds to throw at it to try Cv's.
I'm putting money on its the severe angle of our cv shafts after we lift these things and might just have to deal with it or look into a RCV custom cv shaft. I went through this issue before when I lowered my tuner car, anything over -1.7" of drop caused a vibration when accelerating. I might toss in a new cv to see what happens but am doubtful it will help.
by TangoBravo » Tue Jan 15, 2013 10:08 pm
HARDTRAILZ wrote:Any issues with it before then? I had exact same symptoms and a good alignment cured it.
Agreed.
I had the same issue and a good alignment solved it. The key is to get a good alignment. I alwasy request a spec sheet and usually watch them do it.
TangoBravo
by 2003tv » Tue Jan 15, 2013 10:10 pm
I think i am going to take it to my trans. shop and see what he says because i dont know what to do with it i do have marks 3'' suspension lift kit and 3" body lift do you guys think sears is a good place to get a alignment
Lee
2003tv
