Sears discontinued stocking the Optima batteries in 2007 for a few reasons. One of them had to do with failures (high-rate on red tops), which brought about their introduction of their Platinum line. Sadly, they (Optima) have gone down-hill in the past few years and aren't worth the $$$. Of course, that's a personal opinion so take it as such. I'd personally buy a
DieHard Gold / SUV battery before a red top for use when major power draws aren't a factor.
The Platinums (mfg'd by EnerSys, who also does Odyssey and Naval submarine bats) are pretty good options and the warranty is hard to beat for when major draws are a factor. It's 4yr full, then an additional pro-rated out to 100 months [aka 48/100]. Price is up there at about $190. Their Gold (Johnson Control) is 36/100 for $110 and their SUV (same MFG as platinum, EnerSys) is 36/100 for $118.
Interstate has a few good options, but those are usually their premium line and the same or more $$$ as the
DieHard ones. If you do get an Optima, make sure it's a yellow top. The red top is nothing more than a traditional "start" battery. It's not a "deep-cycle" style battery, where the yellow-top is. Blue tops are a bit hairy since they're intended as marine batteries. Some are "start" service, some "deep-cycle", some both. Depends on the group size.
Also, Optima recently changed their warranty structure (02/01/09.) See their site for more details (
http://www.optimabatteries.com/optima_products/warranty/index.php )
Basically they increased the yellow tops from 12 month free replacement to 36 months (includes audio use or severe service, deep-cycle use.) Basically made it the same duration as the red top. One very important thing to note, which supports my statement about the red tops above being nothing more than a standard starting type battery, is:
Abusive service / Deep Cycle Applications / Car Audio : Not Covered(found under the new red top warranty section)General use off-road could enable that clause, but it definitely would be enabled if used for winching purposes. The mere presence of a winch on the vehicle is enough depending on the area and the retailer.
So, in a nutshell. Go with a
DieHard Platinum or a yellow-top Optima, the Odyssey, or similar. Stay as far away from the red top as possible (no longer an issue since they have same warranty now, just a price difference.)
