Wtb - Disconnect Outer Gear
by larryk » Sat Sep 17, 2016 4:23 pm
Looking for an outer gear in good condition....anyone who has gone awd sleeve should have one :) Mine has some light pitting where the bearing rides....need to replace it
Thanks!
larryk
by Anthony Hernandez » Sat Sep 17, 2016 5:42 pm
Get a new one. Those needle bearings ain't worth a damn.
by larryk » Sun Sep 18, 2016 6:13 am
I'm rebuilding an extra so I'll be ready to install it when I swap my diff. Already have the bearings, washers, and seals. Took it apart to clean, bead blast, and get the rebuild and found the outer gear had pitting where the bearing rides...so I need a replacement. Thanks
larryk
by TBYODA » Sun Sep 18, 2016 11:56 am
larryk wrote:I'm rebuilding an extra so I'll be ready to install it when I swap my diff. Already have the bearings, washers, and seals. Took it apart to clean, bead blast, and get the rebuild and found the outer gear had pitting where the bearing rides...so I need a replacement. Thanks
Most used ones will have pitting, top is from my buddy Cody before he put in the AWD sleeve, bottom is mine after a seal and bearing failure. I personally suggest putting in the AWD sleeve if you rebuilding but for the price of a new one.
http://www.ebay.com/itm/Trailblazer-Env ... railblazer
by larryk » Sun Sep 18, 2016 4:12 pm
Mine looks like the top one.... I have an AWD disconnect, with a good sleeve in it....but I'm still trying to keep the disconnect as designed. I do a lot more highway than off road driving, and don't want to lose that 1-2mpg... Thanx!
larryk
by bartonmd » Mon Sep 19, 2016 9:04 am
They will pretty much all have the pitting in them.
by larryk » Mon Sep 19, 2016 10:23 am
So is this pitting, if it is indeed a common issue, a problem? If I put new bearings in.....will this affect the longevity of them? I typically ensure there is a clean, blemish free surface on all parts that ride directly on a bearing....so this is new territory for me :)
The pitting on mine is slightly less than in the top photo. If this doesnt affect the performance or longevity of the disconnect.....
Thanks guys!
larryk
