BDS 9500
by irishboy02 » Sun May 02, 2010 12:16 pm
Will have them and be installing them on thurs (weather permitting)
Be prepared for a very detailed evaluation, ill be making the transition from the stock bilsteins w/ z71 springs and Mark's rear spacer...aka my current ride quality is in the shitter
2003 GMC Sierra z71
7" FTS lift
irishboy02
by janesy86 » Sun May 02, 2010 1:57 pm
Nice! You should be very happy with those... I have had the 5500's in the rear for a couple weeks now, haven't hit any trails, just my quarries which can get pretty muddy. But on road they are awesome so far.
by Zero » Sun May 02, 2010 2:57 pm
cant wait to see a write up one these new shocks.
by The Roadie » Sun May 02, 2010 3:08 pm
You drove the Roadiemobile for a short time with mine on. But I admit my vehicle's loaded a bit hore hoggily than standard.
by fishsticks » Sun May 02, 2010 10:00 pm
My 5500's have performed superbly off road.
Until today I'd had the rig unloaded when I was out playing. Today I went out with some actual weight in the back, I think the ride actually improved.
I suspect your 9500s will be every bit as great.
by irishboy02 » Sun May 02, 2010 10:21 pm
Yes im hoping so. I chose the 95's over the 55s because i tow quite often, and when i do its for long distances. Along with the towing, i will have additional weight in my truck. (typically a 20' trailer, no brakes with 3-4 quads on it + gear + passengers + rescue equip on 2hr trips + traffic) The valving is the same for the 55s and 95, but the 95s are built for more abuse, so that decision was a no brainer. Plus the obvi stress of wear and tear while wheelin once i get to the location. :flex dirty:
Im really excited to see/feel the difference. Ordered from a shop about 30min from my house, but its worth the trip. Theyre putting my order in tmrw, said they should be here around wed afternoon. So ill be there to pick up before work on thurs.
2003 GMC Sierra z71
7" FTS lift
irishboy02
by Gordinho80 » Sun May 02, 2010 10:39 pm
What shop? OK4wd?
by irishboy02 » Wed May 05, 2010 4:41 pm
Just received a call from the shop. The shocks are in, unfortunately im working so i wont be able to pick them up untill tomorrow morning.
Ill be heading out bright and early for them :excited:
2003 GMC Sierra z71
7" FTS lift
irishboy02
by foosh » Wed May 05, 2010 5:35 pm
I want to see how much longer they are than the z71 shocks ... cause i think i max mine out quite often.
foosh
by Gordinho80 » Wed May 05, 2010 5:47 pm
foosh wrote:I want to see how much longer they are than the z71 shocks ... cause i think i max mine out quite often.
Same length as the 55's...
viewtopic.php?p=12833#p12833
fishsticks wrote:My 5500's arrived yesterday.
A lot of this will be recap for BDS equipped people. But for the ignorant masses (like myself):
Lined up:
by foosh » Wed May 05, 2010 5:58 pm
I feel like they should have a dust cover on them..., but they're really not too much longer.
foosh
by irishboy02 » Wed May 05, 2010 6:05 pm
Not without weight on them, but when weightfrom the truck, eye, gives about 4"
Well find out more tmrw :excited:
2003 GMC Sierra z71
7" FTS lift
irishboy02
by foosh » Wed May 05, 2010 6:11 pm
Hold up, just noticed, we have to use washers to fit these, like the z71 shocks, so whats stoping us from buying lifted tahoe shocks that are even longer?
foosh
by janesy86 » Wed May 05, 2010 6:16 pm
The shocks come with shims that fit perfectly... And they in that pic is the Z71 tahoe shock, which is already longer than our stock or other aftermarket shocks, besides these BDS'
And you can order boot covers if you wish, I don't like em personally.
by irishboy02 » Wed May 05, 2010 6:58 pm
The 9500s come with all the necessary hardware and make install really simple. Tom, you already left when we threw these onto Jeff's truck.
Also remember, the "z71" kit give us 1.5", now a kit with matching shocks would make the shocks, at full length approx 1.5" longer. The 95's excede these by 2-3", giving 5" of shock travel over the oem shock.
These are all approximations. Like i said, ill have more measurements tmrw
2003 GMC Sierra z71
7" FTS lift
irishboy02
by MrSmithsTB » Wed May 05, 2010 7:15 pm
Shoulda hung out, Tom. Seeing them in person is enough to want them. Also, there is a discussion in one of the BDS threads about the setbacks of boots. Based on our area, you could be better off leaving the boots off. Could trap dust and moisture, causing premature wear.
by fishsticks » Wed May 05, 2010 8:47 pm
VS
Both pics are sitting on level ground with no significant weight in the back. I now run with several hundred pounds of tools/gear in the back. It compresses the skinny parts of the Z71 springs a bit, so I'd say I have another inch down from the pic.
Yes, they came with hardware that makes the shock fit properly in our mount. No more washers. 9500's are the same length as these according to the BDS guy.
by fishsticks » Wed May 05, 2010 8:55 pm
irishboy02 wrote:Also remember, the "z71" kit give us 1.5", now a kit with matching shocks would make the shocks, at full length approx 1.5" longer. The 95's excede these by 2-3", giving 5" of shock travel over the oem shock.
The Z71 spring/shock combo gives us 1.5" of height. But a paltry 1/2" of additional extension... as I found out.
The 5500/9500's are 2.5" longer than the OEM shocks. But that 2.5" makes a HUGE difference.
by The Roadie » Wed May 05, 2010 11:03 pm
Anybody buying Z71 springs on Ebay should just say "throw 'em away" to the shocks. Saves shipping.
by irishboy02 » Thu May 06, 2010 7:07 pm
WOW!!
Absolutely in love with these shocks. Have many pics to post up. Might even become a nice how-to for the site (not that its difficult)
Will post when i get out of work at 11
2003 GMC Sierra z71
7" FTS lift
irishboy02
