Lift options
by 05ext » Wed Aug 14, 2019 9:58 am
So I’ve been looking at lifts and found some people do not like the heavy metal suspension lift. Even saw someone refer to it and the “death lift”. What is wrong with this kit? It seems to be a very simple strut extension and spring spacer. Anyone have any insight as to why this kit is so bad?
05ext
by 06denaliman » Thu Aug 15, 2019 8:16 pm
This platform doesnt respond well to that type of lift. If it was a 2wd that lift would likely be perfect but if 4wd you get binding and such. It puts wierd angles and all with it. All other lifts for this platform are either you disassemble strut and install spacer in spring and put back together or you get the adjustable lift shocks like the 5100’s. If your 2wd you can get away with the strut extension lifts. Even some with 4wd have used them with good luck but every vehicle is different (slightly).
06denaliman
by HARDTRAILZ » Tue Aug 20, 2019 4:11 pm
Simply search Death Lift on here and it is explained very well.
by PROSPHOTO » Fri Aug 23, 2019 6:45 pm
I installed a BDS kit with new rear shocks, rear Tahoe springs and new front Bilstein HD struts a few years ago and love it.
-Mike
PROSPHOTO
