Increased stiffness.
by cpyonker » Mon Nov 12, 2018 3:51 pm
I know this has been covered before. But I want a stiffer ride. I already have z71 springs and a 2inch lift. What can I do to stiffen it up more.
Every thread I see only mentions z71s.
cpyonker
by mason10198 » Mon Nov 12, 2018 6:10 pm
Just get stiffer front springs. With only 2" lift blocks in the front, you can go all the way up to '89s if you wanted. (bonus: will also add to your lift a little)
by cpyonker » Mon Nov 12, 2018 7:13 pm
I thought you needed weight on the front for 89s
cpyonker
by wstuckey1 » Mon Nov 12, 2018 8:11 pm
If I understand it correctly, the reason they say you need added weight is assuming that you have max lift already.
02 TB EXT, 4.2, 4x4 w/ G80, 5" lift, 33x12.5x17 Mickey Thompson Baja MTZ, Matte Bronze Fuel Anza 17x8.5, Adapters. North Face Clearance Lights. MDB Fab Armor 1949 Ford F3 (some assembly required)
wstuckey1
by cpyonker » Mon Nov 12, 2018 8:24 pm
Ah, makes sense.
cpyonker
by mason10198 » Tue Nov 13, 2018 10:17 am
Yes, that's to keep you from topping out and breaking struts with a 3" lift and no added weight.
by Trail X » Thu Nov 15, 2018 3:18 pm
If you're too high with the 89s, you can cut a half a spring twirl off, or more depending on your desired ride height.
by cpyonker » Thu Nov 15, 2018 8:56 pm
Sweet, thank you.
cpyonker
