Steering Extension ALTERNATIVE
by mason10198 » Sat Sep 08, 2018 8:48 pm
Credit goes to Regulator for finding/providing this information!
"On the left is an early 2000s Suburban, on the right is the stock Trailblazer shaft fully extended. The mounts on either end are a match. It looks to me this is the solution to the difficult to come by steering extension."Image
by cpyonker » Sat Sep 08, 2018 10:03 pm
Now does it work?
cpyonker
by mason10198 » Sat Sep 08, 2018 11:38 pm
We don't know yet, gotta have somebody try it first! Although everything looks like it should work, if connecting ends are the same, don't see a reason it shouldn't.
by Flyingfischer5 » Sun Sep 09, 2018 1:24 am
If someone buys me a body lift then I'll be the tester.... HAHAHA
Flyingfischer5
by cpyonker » Sun Sep 09, 2018 1:45 pm
How many inches longer is it?
cpyonker
by djthumper » Sun Sep 09, 2018 5:38 pm
The member on FB that posted it is also a member here.
Larry
KC7QJO
by mason10198 » Mon Sep 10, 2018 4:18 pm
djthumper wrote:The member on FB that posted it is also a member here.
Apologies Regulator, I've updated the OP to give you credit :thumright:
by Regulator1175 » Mon Sep 10, 2018 5:37 pm
I will try and get measurements. I am currently in the Battle Creek VA hospital PTSD program. I was out wandering through a local junk yard on Saturday when I decided to pull them and check. Sadly, while my vehicle took box is sufficient to tear down a motor, it does not include a tape measure. I'll figure out a way though......
by Regulator1175 » Mon Sep 10, 2018 6:25 pm
Ok, so I realized that thanks to Battle Box I have a small slap bracelet ruler that came in their tracking themed box a month or two ago. It the best I can do until this weekend, so hopefully it is good enough for the discussion.
Trailblazer extended, Suburban shortened
Trailblazer extended, Suburban extended
Trailblazer on left, Suburban on the right. This is the only noticable difference, but I dont see a quarter turn being an issue. It can probably be corrected in alignment
Trailblazer on the left, Suburban on the right
