A little direction on my Steering rack.
by bljis123 » Tue Dec 13, 2016 10:47 am
So I have had this issue when turning steering wheel while vehicle is NOT moving and it will stall. I replaced my power steering pump no too long ago and that did not stop the issue.
The other day I was in drive way and straightened out wheels while not moving. It almost stalled out. I looked under my driver side and a pile of grease and some oil substance on ground. just a small pile. Look up and it came from inside of inner tie rod, so looks like rack and pinion. Ofcourse all that in there is oiled and greased all over from leaking.
So I got to get in and clean it all up so I can see exact location of leak, but this sounds like the rack and pinion to me??...
How hard is it? Recommendations for replacement? Any thoughts on your experience?
2003 GMC Envoy XL SLT 4x4
bljis123
Vehicle: GMC Envoy XL
by Nexus1155 » Tue Dec 13, 2016 6:23 pm
The system is pretty straight forward with not much to go wrong. If it's not the pump failing, the cooler which is probably super old by now, which a lot of people will be changing soon, and the wack. What it sounds like if you don't have an air pocket and the leak isn't in the front. You possibly have a bad leak on the rack or a bad rack. Look under there some more, because the rack is a pain to replace but there are guides everywhere
Nexus1155
Vehicle: GMC Envoy XUV
by bljis123 » Wed Dec 14, 2016 9:58 am
Thanks for info. I was worried it may be a pain with the location. I'll get under and clean everything to inspect. Never touched a rack and didn't know had a cooler.
bljis123
by Anthony Hernandez » Wed Dec 14, 2016 1:15 pm
Hey man, check your ps lines that run under your battery, they are inside of a rubber cylinder piece, my lines corroded right there and it caused issues for me
by bljis123 » Wed Dec 14, 2016 4:37 pm
Hhhhmmmm, ok thanks will do. Thanks for the reply!!!
bljis123
by bartonmd » Thu Dec 15, 2016 9:30 am
Your engine should be capable of making more than enough power at idle to not stall. I'd hazard a guess is your throttle body needs cleaned, and is stopping it from making the minor throttle corrections at idle (We don't have an IAC) to correct for loads like power steering and such. A cheap/free place to start, anyway.
by bljis123 » Thu Dec 15, 2016 10:24 am
OK yeah it may be gunked up again. Put that on list while I am in there.
bljis123
by Nexus1155 » Sat Dec 17, 2016 11:32 am
The throttle body is something easy and takes under 10 mins if you have long ball allen sockets from Harbor Freight that break a million different ways. It's easy to pop it off and rule anything out. Make sure to remove connection first though.
Nexus1155
