Rear Shock and spring help.
by njdan » Tue Nov 29, 2016 6:10 pm
I have a 2006 TB 4x4 and I replaced the front set up with MOOG-ST8564 Front Coil Spring and Strut Assembly. Now I want to change the rear shocks and springs. Does anyone have any recommendations on which rear shocks and springs would work with the front set up I am using.
njdan
by Jmariano000 » Wed Nov 30, 2016 1:13 pm
I used bilstein hd with tahoe z71 springs
Jmariano000
by bljis123 » Wed Nov 30, 2016 1:47 pm
Bilstein 5125 on mine, but still stock spring with Mark MC spacers.
2003 GMC Envoy XL SLT 4x4
bljis123
Vehicle: GMC Envoy XL
by HawkeyeC25 » Thu Dec 01, 2016 10:55 pm
Jmariano000 wrote:I used bilstein hd with tahoe z71 springs
Same here - very good setup. I also have the MC spacers above this setup, but that would be too much for your setup unless you get the front end up more. The Z71 springs will add about a little bit of lift to the rear so make sure you get matching shocks with the appropriate full extended length.
HawkeyeC25
by HARDTRAILZ » Fri Dec 02, 2016 1:57 pm
I think that you would not want the z71 rears with how the truck sits now. As nice as it sits it would make for some crappy rake. Plus they ride like shit.
I tried the Bilstein HD, BDS, Rough Country, and Skyjacker rear shocks before going to the Bilstein 5125 and wish i had the 5125 earlier. Far superior. I would spend the bit extra and get them.
I do wonder with how yours sits....why you think you need rear springs? The shocks will help any ride issues and you do not appear to need any lift.
