by zerovandez » Tue Jul 05, 2016 1:41 pm
Hi,
Here are specs of my TB
2002 TB 4x4 LTZ
Rear Z71 Tahoe Springs
MarkMC Lift - I'm not sure what version this is. The front are single huge blocks versus the 2 piece that is available. Rear is 3 inch block.
Front Bilstein HD shocks
Rear BDS Shocks
Current wheel/tire size - 265/75/16 (steelie wheels), Tires are Hankook DynaPro ATM
Wheel spacers - 1.5inch 6x5 to 6x5.5 (or vice versa, can't remember)
Here's my problem. I've always had front end problems after the above mods. The TB looks really good and drives really good. But after a month or 2 of driving, I'm always having to replace the front hub, and CV boots. My TB is parked and not driven most of the year. So far, I've gotten the tires/wheels rebalanced, lower suspension arms w/new bushings and front knuckle w/new ball joint replaced. Also got an alignment done. I think the angle that the CV axle sits at is too aggressive - I wouldn't be surprised if the inner joints popped out.
So onto my next move. I want to "level" out the TB but unsure of what lift(s) to purchase. I'm going to get rid of the steelies and install Silverado wheels instead using 265/70/17 tires and they're going to be All Season tires. I don't want a lift that is too aggressive, just something that gets the job done and can fit the said tire/wheel size without much mods. So, with rear z71 springs, which lift would you think better suites my new goal?
Thanks
