Lifting factory air ride (flame suit on)
by cwedge411 » Fri Apr 08, 2016 11:36 am
I'm sure this has been asked a few times, i searched and couldn't find a good answer.
how can you adjust the factory air ride up an inch or 2?
is there a way in the computer to change it? Or is it as simple and welding a inch or 2 tab onto where the sensor is and moving the sensor arm mount on the tension arm up an a bit?
cwedge411
by bartonmd » Fri Apr 08, 2016 11:41 am
No flame suit needed. Somebody with an Envoy could probably tell you, but I've heard tell of just bending the sensor mount.
by cwedge411 » Fri Apr 08, 2016 1:21 pm
I figured the spring conversion people would jump in...Also has anyone tried using the rear spring spacer on a bag. Assuming the bags mount in a regular spring spot, its should work,no?
cwedge411
by ErikSS » Fri Apr 08, 2016 5:38 pm
There is a 10mm bolt head in each rear wheel well. Loosen and turn the sensor behind it. The sensor has a shaft that goes down to the upper control arm. Very very easy process.
by HARDTRAILZ » Tue Apr 12, 2016 2:05 pm
You can just turn the sensor for some lift
by cwedge411 » Thu Apr 14, 2016 2:16 pm
Awesome! thanks all!
cwedge411
