sicklife17 wrote:So for a long time now there has been a clunk in my front end over bumps. I was told it's the sway bar links. And the struts were squeaky. So I finally replaced Bassicly everything and added a 2.5" lift. It is now clunking worse then before. I no that there was a part on the Blazers under the drivers door that was common to break and broke on my girlfriends Tahoe. She had the same sounds I'm having and I can't figure it out. Does anyone no what it could be?
The torsion bar crossmember mount thingy that broke on your GF's Tahoe doesn't exist on a Trailblazer, so it's not that.
Unfortunately many front end parts clunk when they're bumped, so I can't tell you any one part to go look at. Balljoints, especially uppers rattle alot. Could be control arm bushing's, could be the strut's topping out, could be your sway bar endlink's. You said you added a lift and replaced "basically everything" but that isn't a very clear parts list lol.
