by v7guy » Mon Jun 01, 2015 8:20 pm
The biggest issue is how tall do you wanna make it. You have to go below the factory subframe to make it work. That means a mighty tall ride height. If you're ok with that, build a way!
If your only goal is to just go sky high and put 42s on it, drop the diff below the subframe, drop the a arms straight down and use all stock parts and change wheel bearings every 6 months. Would be relatively simple and straightforward.
build thread All things in moderation, including moderation.
