Radflos
by The Roadie » Sun Oct 19, 2014 5:29 pm
Tapatalk spam signatures still bother me.
by MK-voy » Thu Nov 06, 2014 4:36 pm
Hi please could someone help to order the radflo I have contacted wheelers they gave an email but no one replied.
plz help. Should i match the radflo with c25 skyjacker and shocks.
MK-voy
by HARDTRAILZ » Thu Nov 06, 2014 5:49 pm
Give them a call
by ErikSS » Thu Nov 06, 2014 10:12 pm
I checked out my receipt from when I bought mine. It says they were part number "RAD 5CC-002-00." I typed that into Wheelers site, it didn't come up with anything. Perhaps it will help you when you call them.
by bartonmd » Fri Nov 07, 2014 9:30 am
Johnny isn't at Wheeler's any more, so if the email you sent it to was his, then it may or may not get to anybody, depending on how often they check it or if they have it forwarding to somebody else... You might contact Radflo directly and see what they have to say...
(ETA: I just sent my contact at Radflo an email, sending him this thread, and asking him where these can be ordered)
by MK-voy » Fri Nov 07, 2014 10:15 am
Thank you
MK-voy
by bartonmd » Mon Nov 10, 2014 2:59 pm
Mike Crosby emailed me back, from Radflo. They were apparently made specifically for Wheeler's, and they'd have to be bought through them.
by bartonmd » Mon Nov 10, 2014 3:09 pm
I called Wheeler's and talked to Dan. He's apparently been handling the TB/Voy coilver stuff since Johnny left. He said that his emials should be getting forwarded to him, but they've been having trouble with hotmail addresses and stuff not working. You can send him an email at dan at wheelersoffroad dot com, or you can call the number on the website, which is what I just called and it got picked up on the second ring, which is Five Four One 474 two 879.
by MK-voy » Mon Nov 10, 2014 3:17 pm
Thank you mike for your help
MK-voy
by bartonmd » Mon Nov 10, 2014 4:38 pm
No problem.
by MK-voy » Thu Nov 13, 2014 3:50 pm
No body answering my email will try calling.
MK-voy
by HARDTRAILZ » Thu Nov 13, 2014 3:54 pm
Did you not read where Mike said they were having email issues and gave you the number to call 3 days ago?
by bartonmd » Thu Nov 13, 2014 3:56 pm
MK-voy wrote:No body answering my email will try calling.
I had thought you were from Lebaon, Indiana or Lebanon Tennessee or something, but looks like you're from Lebanon, the country... If so, I suspect your email is going to SPAM on their server. If you don't want to give them a call, you can send me a message and I'll email it to them and give them your email address.
by JoeyV » Sat Nov 15, 2014 11:28 am
MK-voy wrote:Hi please could someone help to order the radflo I have contacted wheelers they gave an email but no one replied.
That's what I have on my rig and enjoy that set-up. I still haven't had much offroad time, but so far it has handled great on and offroad. Inevitability, you will not be able to level out the vehicle and will have forward rake.
JoeyV
by ErikSS » Sat Nov 15, 2014 7:43 pm
You also asked about the rear springs. This is an opinion based question. Those who run the Skyjacker C25 rear spring like them. The majority of us are running the Z71 with great success also. The Skyjacker is a little bit softer of a spring rate than the Z71. Personally, I like the Z71 as a match for the Radflo because it also is a high spring rate. I can see merit in the softer ride though.
by HARDTRAILZ » Sun Nov 16, 2014 9:52 am
I don't have rake w radflo n skyjacker. I like the pairing.
by MK-voy » Sun Nov 16, 2014 7:33 pm
the c25 and the z71 give the same amount of lift, I am planning to go with 33 inch tires with out a body lift.(is it possible)
MK-voy
by Moots1288 » Sun Nov 16, 2014 8:07 pm
MK-voy wrote:the c25 and the z71 give the same amount of lift, I am planning to go with 33 inch tires with out a body lift.(is it possible)
The Skyjacker give you 4 inches of lift with out a block, the z71s you have to run a lift block with them.
by v7guy » Mon Nov 17, 2014 7:30 am
My envoy runs 33s and no body lift, it works fine.
