I figured I would give my general impressions so far. I was kind of doing a couple things at once. Tires, front struts, rear coil conversion from air bags and 2.5" MarkMC (Liftmeister) suspension lift. The back half went smooth enough other than my learning curve. Took about 2 hours or a little more. Half of that was dealing with the air bags, getting one out that decided to come apart and leave the top part still in the car. After that was done I compressed the rear springs and tried to slide them up in there. Word of advice, have the nut side of the spring compressor facing down and the bolt head side facing up or it is just not going to fit in there right. Try as I may, I was unable to figure a way to make it fit in there and decided to pull it back out and flip them the other way. Side two went much faster after having already figured this out. So I got the back part on. I have decided to get front installed by a local shop. It is cheap enough and would have cost me $50 for them to assemble the struts or $140 to do the whole job. I figured I would let a pro handle this half.
