So Ive decided to lift my TB
by Me007gold » Mon Aug 23, 2010 12:06 am
Ive decided I want to lift my TB, Done a lot of reading here and at trailvoy, and this is what Ive come up with
MarkMC Full kit
MarkMc 1.5" Spacer
Z71 Springs
Bilstein HD Shocks
Am i missing anything?
Me007gold
by MrSmithsTB » Mon Aug 23, 2010 12:58 am
First, I think you need to define your mission. Since you're on this site, I assume it is going to be for functional off roading. MarkMC's lift, Z71s, and Bilstien front struts are a good start. If you are planning to replace the rear shocks, BDS makes decent ones for lifted TB applications. You should also plan on getting an oil pan skid plate at the very least. And how about tires? Depending on size, you could be involving spacers and maybe new wheels. Anything larger than 30.5" inches will require spacer of 1.5" to clear the upper ball joints. Check out some of our build threads. It will give you a good idea as to what certain mods will accomplish, and you can make a shopping list from there. You took the first right step. You're here :fro:
by Me007gold » Mon Aug 23, 2010 1:11 am
I was planing on doing the Bilstien HD's in the rear as well. Would the BDS's be that much of an improvemnet. For tires I was thinking about running 265/75/16's
Me007gold
by fishsticks » Mon Aug 23, 2010 1:24 am
Me007gold wrote:I was planing on doing the Bilstien HD's in the rear as well. Would the BDS's be that much of an improvemnet. For tires I was thinking about running 265/75/16's
If you are going to replace your rear shocks, using the BDS shocks is a no brainer. They are similarly priced to the Bilsteins and work much much better on a lifted truck.
by HARDTRAILZ » Mon Aug 23, 2010 8:37 am
:Iagree:
by KE7WOX » Mon Aug 23, 2010 10:45 am
:Iagree:
by Gordinho80 » Mon Aug 23, 2010 10:56 am
Like Bob said... what is your goal? What do you plan on doing with your lift?
Also... if you're lifting the rear and replacing shocks, you'd be a fool not to go with BDS 55619s or 95619s, at minimum.
by Me007gold » Mon Aug 23, 2010 2:15 pm
Gordinho80 wrote:Like Bob said... what is your goal? What do you plan on doing with your lift?
Something thats functional off road, nothing hard core as this is my DD, cant afford it to be down to long. as well as looks good sitting on 32" tires
Me007gold
by Gordinho80 » Mon Aug 23, 2010 2:19 pm
Sounds like my goal... check out the Build Threads... lots of great info in mine as well as others'.
by MrSmithsTB » Mon Aug 23, 2010 2:27 pm
Gordinho's rig is built well. Study his thread as well as others. As stated, Marks lift is a good start, Z71 springs, Biltsien struts, BDS shocks, wheel spacers, tires of choice, a little under armor, and maybe some recovery equipment to start. Shouldn't ill the wallet to badly and should give you some off road capabilities while keeping it driveable every day. Remember, the down time is determined by the way you drive off road, not the mods you do.
by HARDTRAILZ » Mon Aug 23, 2010 3:00 pm
Mine is a DD and does trips to far off wheeling spots. Go all out and use it. The jaw drop factor you will see on tougher trails is worth it.
by irishboy02 » Mon Aug 23, 2010 3:36 pm
Good goals. With those tires your definatley going to need spacers as well.
2ndly, i HIGHLY recommend the BDS rear shocks. Im currently running the 9500s on my truck, i have a thread on here about them. They also have a much more cost effective setup, their 5500 series which quite a few people are running. Definately look into it,especially if your going to run the 'z71' with the higher spring rate (which im sure your already aware of)
2003 GMC Sierra z71
7" FTS lift
irishboy02
by fishsticks » Mon Aug 23, 2010 5:09 pm
HARDTRAILZ wrote:Mine is a DD and does trips to far off wheeling spots. Go all out and use it. The jaw drop factor you will see on tougher trails is worth it.
:Iagree: Mine is both my DD and my "Company" truck, I mod it the way I do because I have the confidence that things will hold up and if they don't I can have it fixed in a day or less.
I had to roll up to a client's house this morning covered in dirt, because I spent extra time yanking an Explorer out from between two rocks yesterday and didn't get home until dark. No time to wash it this morning.
It was quite the conversation starter. :coffee2:
by HARDTRAILZ » Mon Aug 23, 2010 10:48 pm
Well done Fish. i rolled mine to work covered in mud and had conversations at stoplights... :excited:
by Me007gold » Tue Sep 07, 2010 10:32 pm
Well the lift and springs are here. Order the shocks next week. Then comes the search for wheels and tires. Hope to have everything done by the end of october
Me007gold
by HighSierraTB » Tue Sep 07, 2010 10:57 pm
Make sure you post to a build thread as you go along. The one thing I usually forget to do is to take before and during shots of any of my projects, only after shots....
HighSierraTB
by Me007gold » Tue Sep 21, 2010 6:31 pm
Ordered the 5500's saturday, They will be here Friday. next week ordering front shocks, the week after that wheels/spaces. While I am down there, would it be wise to just replace the CV half shafts and the end links? currently I am at 61xxx miles
Me007gold
