The Roadie wrote: Icons are giving me a taller rest height in the front, even with the adjusting collars all the way down. So the camber is out of spec and can't be brought back in without fabbed upper control arms..
HARDTRAILZ wrote:Both my rear ones are dented. Anyone thinking about something for the rear to push the axle back an inch or 2?
Tecore had some discussion of the control arms. Alek has some research involved already if he is willing to share.
MrSmithsTB wrote: In order to keep the camber in spec for an equivalent lift, the arms will need to be 1" shorter than stock, or 2" shorter than the DJM arms.
fishsticks wrote:MrSmithsTB wrote: In order to keep the camber in spec for an equivalent lift, the arms will need to be 1" shorter than stock, or 2" shorter than the DJM arms.
Negative ghost rider. We can use the extra 1" of length on the UCA. The tops of our wheels get pulled in as the suspension extends, similar to what happens to the lowered guys. The balljoint end of the UCA is past the fulcrum in the opposite direction for us.
Bill, if you're willing to ship (I'll pay) and don't have a better offer, I can send them over to my friend (ironically also named Bill).
MrSmithsTB wrote:That's what I initially thought as well, but did you take a look at your front end before getting an alignment after lifting? I don't know about your truck, but my wheels git sucked under a little bit. Kinda like this:
Now correct me if I am wrong, but an extra inch up top would angle the wheels even more severely making it even harder if not impossible to align. Therefore, one inch less would bring the camber closer to spec, making it much easier to achieve a true and hassle free alignment.
Also, I think this might be a good time to split off the discussion into another thread. Mods? Where are you?
bartonmd wrote:MrSmithsTB wrote:That's what I initially thought as well, but did you take a look at your front end before getting an alignment after lifting? I don't know about your truck, but my wheels git sucked under a little bit. Kinda like this:
If the upper control arms are shorter than the lower ones (which I think they are on ours), we would benefit from longer ones...
