my nitro N8030's are 26.57 but I'm not disco'ed.
I had a hard time prying in my Z71's and a 3/4 inch spacer.
Opeth wrote:I am running Z71 springs, Mark's spacer and the Bilstein 33-185552 10" (255/70) valving.
So I bought some grade 8 (1/2")x13-4" long galvanized bolts and 12 1/2" washers.
Truck is once again silent over bumps.
Also, one 1/2" washer needs to be used on either side of the top bushing to eliminate the gap in that mounting location as well.
The steel bushings I cut are 1.5cm long, 1/2" shock bushing/washers.
Would totally recommend these in replace of the pricey BDS Fox 2.0 shocks. Plus these also come with boots, unlike the fox's.
