Moots1288 wrote:ErikSS wrote:v7guy wrote: A bit softer/bouncier, which could be good or bad. But I've not been in his truck with hundreds and hundreds of lbs in it.
IMHO, Bounce is always bad.
It doesn't bounce that much, I like ride much better then z71s and white body bds shocks. Really don't know how the ride is with z71s and gas shocks.
I'm calling bullshit. Moots ran around with the z71s for a lil while with the fox shocks if I'm not mistaken and he's spent a pretty significant amount of time in my truck. For the record, he's told me he doesn't care for the way my truck rides. On the other hand TBYODA was in my truck the first day of the last TECORE and while I was romping on it through the switchbacks and moving over the washboard sections he made a comment that I was moving pretty good, but I'm very comfortable in the truck in it's current (ever self destructing state) and new exactly how it was going to react, I've never heard him mention to me the truck rode poorly.
The thing that struck me most about Moots is when we were at Badlands going over some heavy washboard stuff the rear end bounced hard, as did the front, but it seemed to be a bit of a teeter totter effect where the rear was bouncing a tremendous amount and pitching the front. The front and rear didn't really feel like it was in sync. Now obviously that's likely not so much a spring problem as it is a
shock problem. I would assume the
shock would need to be a little stiffer to keep from getting the wheel hop. It probably doesn't need to be a lot stiffer, but a little bit. The rebound felt alright to me, the spring/
shock seemed to return the axle back down quickly, but it was just in time to hit the next rise and slam the axle back up.
In Lacey NJ I found that over the washboard stuff the z71s with the fox shocks rode pretty decent, there wasn't near the pitching and heaving that I felt in Moots truck. My front end was still topping out as I came over the rise, and ultimately I broke one
shock, but the rear end felt planted and I didn't get the teeter totter effect Moots had. Unfortunately in some situations the rear does feel a little too stiff, but again it's probably a bit more of a
shock issue (where it needs softened a smidge). The rear skates a bit in the smaller washboard stuff and I could see it being a problem for some people. I'm pretty familiar with a vehicle that's tail happy though and I'm very comfortable getting it to act like I want... I prefer the skating to something like Moots has where it pitches the whole truck around.
The end result may have very little to do with the spring itself and actually have more to do with the
shock we're using with the respective springs. Outside of getting some shocks that you can tune yourself, or one that's dual adjustable I'm not sure you're going to easily solve it without spending a lot of time and money just tossing on different shocks.
As mentioned before, there's a fair amount of personal preference to be considered when making a decision which route you want to choose. I also suspect there's a really good compromise out there to keep the truck from pitching so much and to keep it from skating. For most of us though both setups work reasonably well in most situations and the parts we've been using is just a compromise on readily available cheapish parts that we can adapt.
you can find more info about it all...
viewtopic.php?f=15&t=1747viewtopic.php?f=15&t=411viewtopic.php?f=15&t=260
