LT275/65R17 on 17x9 Rim?
by Akozlowski » Tue Mar 09, 2010 8:15 pm
I noticed many of the sizes that have been posted are for a 17x8 rim size, what if I was going to go up to a 17x9? Here is what I am looking at and what I plan to do to the vehicle.
Lift:
Rear Z71 springs
DBS 2'' front and rear
Bilstein HDs all around, if I can.
Wheels:
Fuel D531 Hostage 17x9 4.5 backspace
Tires:
Heres the issue, getting the recommended clearance so that I don't have to modify anything else.
After looking at diameter charts it shows that if I go with BF Goodrich All Terrain T/A KO Tires
LT275/65R17/E RWL 26795 7.5 - 9.5 31.2 15 3195@80 so the overall diameter being 31.5 would I be ok because of the 4.5 backspace on the wheels and if that was ok will they stick out the sides too much?
These wheel/tire options are strickly because I was trying not to run spacers and I currently have a 16inch rim that doesn't look anything as good as the newer 17'' stock. Any opinion would be amazing or if there are other wheel option in black with 17x8 6/5 pattern
Akozlowski
Name: Adam Kozlowski
by HARDTRAILZ » Wed Mar 10, 2010 10:39 am
Akozlowski wrote:I noticed many of the sizes that have been posted are for a 17x8 rim size, what if I was going to go up to a 17x9? Here is what I am looking at and what I plan to do to the vehicle.
Lift:
Rear Z71 springs
Wheels:
Tires:
The tires will looked stretched and the edge of the rims will be very unprotected. I have 9 inch wide with 305 width tires and they create almost vertical sidewall. I would not go any skinnier with the tire on a 9. If i was doing it again, I would get 8 inch wide rims. Mine stick out a good ways, but i have the 1.3 inch spacers.
Basically 275's may fit the wheel but will be stretched, I hate that look and the risk of popping the bead, but it is your truck.
by Trail X » Wed Mar 10, 2010 10:59 am
For your reference, the stock wheels have a 7" rim width and 6" of backspacing.
So just remember that by going to a 9" rim with 4.5" of backspacing, your inner rim will be 1.5" further out, while your outer rim will be 3.5" further out than stock.
by Akozlowski » Wed Mar 10, 2010 9:25 pm
Ya thats bad news, I knew I was missing something when figuring this thing out, haha well I will just have to go with spacers. Many of you guys use them with no problems I don't know why im being so worried. My current set of wheels are the 16'' I noticed many of you guys have the 17" im assuming the width is the same on both pairs? Either way spacers it is! Thanks guys :excited:
Akozlowski
by Trail X » Wed Mar 10, 2010 10:03 pm
Yes, as far as I know it's 7" rim width on both the 16" and 17"ers.
by Zero » Mon Mar 15, 2010 8:30 am
I thought this thread was not for discussion.....but only for people to post their suspension setups?????? All this chatting is gona make it hard for new people to just read through the thread and get the info the came for.
by Gordinho80 » Mon Mar 15, 2010 10:31 am
I agree with Zero.
New Thread created
