The Roadie wrote:Neil's still waiting for his first East Coast order for gas tank armor.
I've asked him for a cost on an aluminum one... he never replied. I'm not going steel. It's way overkill for me and it will rust here in no-time.
janesy86 wrote:Not tryin to put down your dream of 35's, because its your truck and you can obviously do whatever you want but I don't think its practical if you want to wheel it hard. Plus your goin to be stressing a lot of parts more than we already are with 32/33's..
bgwolfpack wrote:bobbyblaze wrote:I currently have 4:636 gears. When my current rubber gets down to 50% i'm goin' up to 32X12.5 M/T's and changing my gears to 4:90 to correct the speedo/odometer and a little more power/torque.
Would be a real good idea to up those gears with 35's.
You may want to change your vehicle info to other, so not to confuse those who don't know you jumped ship.
foosh wrote:An all suspension sas would be best, but wheeling up here is all related to how big your tires are, and not very much your center of gravity issues... bigger tires= more mud moved and being able to go truth the center of the trail without worrying about framing out in a mud/water pit or going through to deep of ruts.
The Roadie wrote:I should post some pics, but the firewall issue is in the footwell area where it makes room for your toes. Mine's shiny where the tire's been buffing it when slightly turned and then you compress the springs. Far worse when I had weak springs. It can be sledgehammered back a bit. Oh, it's also worse when you whack the tire or lower control arm into things and the lower control arm bracket slides back in its adjustment slots - it throws caster off, but also reduces the clearance at the rear of the tire. Even with 200 ft-pounds on those three bolts I keep sliding the bracket rearwards.
After vowing in 2006 to never get a body lift, and just paying the price for that short-sighted decision by having Neil move my rock sliders and front bumper up, I have to RE-vow that 2" is it. The Roadiemobile is going to stay at 2" body lift until I get some terminal disease and pull a Thelma and Louise with it, and everything else that needs sledgehammering or Sawzalling to fit 34's is just going to get sledgehammered or Sawzalled.HARDTRAILZ wrote:Stepping up to the 3 inch body will eliminate the tire rubbing.
