Factory steel wheel specs?
by eschy1990 » Thu Mar 03, 2016 8:12 pm
Anyone know the specs for our factory steelies? 17×7 and 6×5.0 is all I can find online is the offset any better then our regular 17×7's?
eschy1990
Name: Jeff Eschenbacher
by Rickalicka18 » Thu Mar 03, 2016 9:45 pm
I believe our offset is +35. Are you trying to find a rim with enough offset to take out the wheel spacers?
Rickalicka18
by Jrgunn5150 » Thu Mar 03, 2016 10:58 pm
eschy1990 wrote:Anyone know the specs for our factory steelies? 17×7 and 6×5.0 is all I can find online is the offset any better then our regular 17×7's?
I could be completely wrong, it happens all the time, but I'm pretty certain a fullsized spare would have the same offset as stock.
by DirtyBacon04 » Fri Mar 04, 2016 4:12 pm
I believe Jr is right.
by Rickalicka18 » Fri Mar 04, 2016 4:13 pm
Lol I didn't see the "steel wheel" part. I also agree with jr though
Rickalicka18
by HawkeyeC25 » Fri Mar 04, 2016 11:33 pm
I agree that the full size steel spare has the same specs as the 17x7 Aluminum wheels. Which have a 50mm offset.
HawkeyeC25
by eschy1990 » Sat Mar 05, 2016 1:31 pm
I'm just looking at different wheels and struggling to find anything decent for not a lot of money it kind of looks like the offset is a little less the alumi's but no websites will tell me what the offset is I'm keeping my spacers as well...
eschy1990
by Rickalicka18 » Sat Mar 05, 2016 1:39 pm
If your looking for new rims, I used customwheeloffsets.com. They have atleast three or four wheels with our bolt pattern. One would be custom drilled, and I believe the other three have dual patterns. Also, when searching it helps to put 6x127, rather than 6x5.
But if you want to keep the spacers I wouldn't go lower than +25 offset. Would be easier to buy the adapters to have the 6x5.5 bolt pattern, since its a common bolt pattern
Rickalicka18
by HawkeyeC25 » Sat Mar 05, 2016 6:21 pm
+1 on the going with 6x5.5 Adapters! Also, +1 on the 25mm offset with spacers. Check out my build thread for some before and after pics of stock tires and stock 17's compared to 1.5" adapters and 17" aftermarket's with 25mm offset. I found it very difficult to find anything that appealed to me in the 6x5 bolt pattern.
HawkeyeC25
by Jrgunn5150 » Mon Mar 07, 2016 6:54 pm
HawkeyeC25 wrote:I found it very difficult to find anything that appealed to me in the 6x5 bolt pattern.
That's not likely to get any better as time goes on either. I also agree with adapters instead of spacer's. There's nothing to fear as far as durability goes from either.
