Question about fitting 265/70/17 tires
by The_Convoy_ » Mon Feb 29, 2016 6:36 pm
What spacer do I need without rubbing? The stickied thread about tire and lift size says I need a spacer and a 2" lift and won't need to trim anything, but I don't want huge spacers.
The_Convoy_
by DirtyBacon04 » Mon Feb 29, 2016 9:31 pm
1.5" is the standard size you'll see. It allows the spacer to clear the stock lugs without having to grind them.
by The_Convoy_ » Mon Feb 29, 2016 10:58 pm
DirtyBacon04 wrote:1.5" is the standard size you'll see. It allows the spacer to clear the stock lugs without having to grind them.
OK I'm planning getting those, MarkMC's 2.5" leveling kit and some STT Pros! Thanks :flex dirty:
The_Convoy_
by Jrgunn5150 » Tue Mar 01, 2016 12:01 am
Ooh, I'm interested to hear how you like the STT Pros
by HawkeyeC25 » Tue Mar 01, 2016 12:28 am
I've got the STT Pro's with the spacers and lift, but they are 255/75/17. Same diameter, but 10mm narrower. They have been great so far! Pretty quiet on the road for a mud tire! Here's the first real test... viewtopic.php?f=62&t=6376 Sure I got stuck, but on first pass I got an entire EXT into 3 feet of snow :P
HawkeyeC25
by Cable810 » Tue Mar 01, 2016 10:10 am
They aren't quiet in a 37x13.5x17. I can hear them in the cab over my exhaust and I've got a glass pack on. At lower speeds however they are quiet..... I personally think they could be just a tad louder.
