255 75 17 tires
by Jrgunn5150 » Thu Jun 11, 2015 1:44 pm
Spacers are a variable thing depending on where you are.
My local Walmart wouldn't touch em. Mom and pop shop didn't blink while they beat the wheels off them with a hammer
by Cable810 » Fri Jun 12, 2015 7:48 am
v7guy wrote: For example, we have a guy that went from not owning enough tools to put in a lift and was scared to even attempt it that's in the middle of a solid axle swap!
I about spit out mu breakfast when I read that Rofl. It is true though.
by jamesrivers4 » Sun Jun 14, 2015 11:50 pm
New tires on, and found some mud
Sent from my SM-N900T using Tapatalk
jamesrivers4
by jamesrivers4 » Sun Jun 14, 2015 11:51 pm
jamesrivers4
by v7guy » Mon Jun 15, 2015 12:42 am
Looks good, did you have to do anything extra?
by jamesrivers4 » Mon Jun 15, 2015 10:25 am
Just had to cut some of the body trim that stops at the rear of the wheel well, next I plan on getting a radiator and oil skid as well as after market wheels
jamesrivers4
by jamesrivers4 » Mon Jun 15, 2015 10:37 am
Also if anyone else is looking for wheels I found these (mb-tko 17" 0.25 backspacing) at discount tires for 650$ not bad I'd say...Image
jamesrivers4
by jamesrivers4 » Mon Jun 15, 2015 10:42 am
Correction* 0.25 offset
jamesrivers4
by BC backroader » Mon Jun 15, 2015 12:20 pm
I like those wheels in the version that has polished accents.
by jamesrivers4 » Mon Jun 15, 2015 12:45 pm
I was looking at those also but they seem to be suddenly unavailable
jamesrivers4
by jamesrivers4 » Mon Jun 15, 2015 1:59 pm
Were you reffering to these?
jamesrivers4
by jamesrivers4 » Mon Jun 15, 2015 2:28 pm
I also found a website that will drill the patter for you, and for 650$ you can get theseImage
jamesrivers4
by jamesrivers4 » Mon Jun 15, 2015 2:33 pm
http://www.bbwheelsonline.com/raceline- ... d_search=0
jamesrivers4
by zippyhead » Thu Jun 18, 2015 11:17 pm
I have the exact same tires in the same size. I have no rubbing in back, just a little in front that was solved with a ziptie to pull the plastic liner forward a bit. and I have a 3" MarkMC lift btw.
zippyhead
