Wheel offset
by sicklife17 » Tue Apr 14, 2015 6:38 pm
Ok so I have been reading for hours now and I am totally confused. I just need a simple answer. I am thinking of getting new wheels instead of spacers and I don't no what back spacing to run. I don't no if I am going to get 7-8" wide rims but either way my understanding is I need 4.5" of back space to clear 32s. Now as for off set I have no idea. But I don't really think it will matter to much.
sicklife17
by Moots1288 » Tue Apr 14, 2015 6:54 pm
our bolt pattern is very odd and doesnt have many selections, you will need atleast adapters to run a wheel with 4.5 backspace. and guys have 32's on stock wheels with spacers.
by southernrootz93 » Tue Apr 14, 2015 7:19 pm
Dick cepek has a dc2 that is our bolt pattern in 16s with a -12 offset and 4.5 offset. I Plan on getting them with a 2" spacer so I can squeeze a set of 305/70/16 on mine with the 3.5" lift in front and 1" in back.
if it ain't broke, don't fix it.
southernrootz93
by sicklife17 » Tue Apr 14, 2015 7:27 pm
I no we have a weird bolt pattern. I would rather just run different rims then spacers so what would be the optimal back spacing to run 32s with out spacers
sicklife17
by southernrootz93 » Tue Apr 14, 2015 7:29 pm
Also from my understanding our stock wheels have a +24 inset so therefore the rim is more in toward the vehicl, but if you had a rim with a -12 offset it would bring it out more away from the ball joint giving you more room for a taller tire.
southernrootz93
by southernrootz93 » Tue Apr 14, 2015 7:40 pm
You can run an aftermarket rim with 4.5" of back space as long as it has enough offset to bring the rim out to clear the ball joint.
southernrootz93
by sicklife17 » Tue Apr 14, 2015 8:34 pm
Ok I just need a simple answer. How much back spacing/ offset is optimal to run 32s with out spacers. I need numbers most likely buy a used set this weekend and the only thing I have to go off is my handy dandy tape measure
sicklife17
by southernrootz93 » Tue Apr 14, 2015 8:43 pm
Well you need a rim with 4.5" backspace and it has to be a offset of 0 or lower.
southernrootz93
by sicklife17 » Tue Apr 14, 2015 9:02 pm
What best offset
sicklife17
by southernrootz93 » Tue Apr 14, 2015 9:10 pm
-12
southernrootz93
by Moots1288 » Tue Apr 14, 2015 10:07 pm
they dont make DC2 in our backspace... they have 6x5.5 we have 6x5
by southernrootz93 » Tue Apr 14, 2015 11:16 pm
They do too.. They don't have it as 6x5 on there site, they have it as 6x127 which is a 6x5.
southernrootz93
by southernrootz93 » Tue Apr 14, 2015 11:45 pm
Well I re-researched the topic and cannot find the dc2s now.. I swear on everything they had a dc2 on there web page that was 16x8 with a 6x127 pattern with -12 offset.. But now it's gone.. So therefore you will have to have an adapter to fit the 6x5.5 like moots1288 said earlier.. Sorry for the confusion..
southernrootz93
by HARDTRAILZ » Wed Apr 15, 2015 12:32 pm
The needed offset will vary by width of the rim. Easier and more consistent to just look at backspacing. Simpler to measure if you are looking at used wheels as well.
Example:
8 inch wide wheel with 4.5 inch Backspacing is 0 offset
9 inch wide wheel with 4.5 inch Backspacing is -12 offset
by v7guy » Thu Apr 16, 2015 3:22 am
viewtopic.php?f=14&t=26
The sticky at the top of this page specifically answers the question in the first post! What's ideal will vary by the width of the wheel you're using and what size tire you're trying to cram in there.
by Ole Blue » Thu Apr 16, 2015 1:22 pm
I have 6x5 wheels 17x8 22mm offset with no spacers running 265/70/17 (no rubbing).
Ole Blue
by BC backroader » Thu Apr 16, 2015 1:54 pm
What wheels do you have, Ole Blue? That is the size tire I'd like to run, but I don't think they'll clear the UBJ with the OEM rims. I like the MB wheels Chaos, which has enough backspace to work with those tires, and comes in our bolt pattern, but there aren't any to be found in North America right now.
by v7guy » Fri Apr 17, 2015 9:58 am
It's in his build thread believe it or not!!
viewtopic.php?f=74&t=4463&p=101393#p101393
by BC backroader » Fri Apr 17, 2015 2:12 pm
Thanks for the link, v7guy, I should have thought to look there myself. :work:
Those are good looking wheels, now I'll do a search for them :salut:
