1.5 Clearance Issue Help
by MelloYello88 » Wed Apr 10, 2013 7:57 pm
Looked through a number of threads and didn't see anything that addressed this so far and not sure how to figure the measurements. The question is with only a 2" cross country lift is there any issues with running the 1.5"s spaces. Top center of the wheel wells is looking real close to me. Not looking to do crazy wheelin with it at this point but I have been known to take roads less traveled. Stock 04 LS rims and tires listed below.
My thinking is 2 inches up and 1.5 inches out I should be clear of the fender in a full stuff situation just don't turn the wheel and keep the line.
Thanks Much
Owned from "New", AirAid CAI & Throttle plate spacer, Rough Country 2" frt lift 3/4" rear lift, General Grabber AT2 255/70R16, Powerstop truck and tow rotors & and pads
MelloYello88
by navigator » Wed Apr 10, 2013 8:52 pm
I ran that same setup you have , 255/70/16, 2" RC lift and 1.5 spacers. You shouldn't have any problems.
I expect you wouldn't have any problems up to a 265/75/16.
you can always jack up one side as far as it will go to give you an idea but you should be fine with what you have.
by DirtyBacon04 » Wed Apr 10, 2013 9:01 pm
you couldn't find the answer to that question?
by MelloYello88 » Wed Apr 10, 2013 9:29 pm
DirtyBacon04 wrote:you couldn't find the answer to that question?
I'll answer that with a question of my own....... Did You? Don't be bogartin it! :poke: :poke:
MelloYello88
by TangoBravo » Wed Apr 10, 2013 10:37 pm
TangoBravo
by djthumper » Thu Apr 11, 2013 1:04 am
TangoBravo wrote:http://forums.offroadtb.com/viewtopic.php?t=20
Took all of 4.237 seconds
You also have this chart viewtopic.php?f=14&t=2290
So maybe you missed this link that has links to the answer as well.
by jonbo2002 » Thu Apr 11, 2013 1:36 pm
:facepalm: :wallbash:
jonbo2002
by MelloYello88 » Thu Apr 11, 2013 2:17 pm
viewtopic.php?t=20.... Did not see this Good stuff! Thank You!
viewtopic.php?f=14&t=2290..... Saw this but was uncertain due to Navigator having a higher over all platform at least from the specs and pics in his build tread.
Thanks for your input Navigator, I appreciate it!
To anyone I frustrated by making them read the thread I do appologize!.... I crown myself :safe: of the borad for the day :oops: I hope I didn't hurt you to much!
:P
MelloYello88
by navigator » Thu Apr 11, 2013 2:34 pm
MelloYello88 wrote:... Saw this but was uncertain due to Navigator having a higher over all platform at least from the specs and pics in his build tread.
that was my fault, I just upgraded tires etc. I updated my build and added myself to the new tire size but didn't remove myself from the old tire size. :wallbash:
by MelloYello88 » Thu Apr 11, 2013 3:14 pm
[/quote]
that was my fault, I just upgraded tires etc. I updated my build and added myself to the new tire size but didn't remove myself from the old tire size. :wallbash:[/quote]
All good! That was why I posed the question... :cheers:
MelloYello88
