Lift/Tire Size Chart
by djthumper » Wed Apr 17, 2013 2:45 am
JorDaneeKey wrote:
darring70 wrote:I did not know you can run 35's on 3.73 gears
We do. The gas mileage sucks though, and you have to be careful not to put too much stress on the rear to the point you'll grenade it. We'll be upgrading to 4.10s by summer.
4.56 would probably yield you guys better results.
by JorDaneeKey » Wed Apr 17, 2013 5:43 am
Yeah, we keep going back and forth on those.
JorDaneeKey
by HARDTRAILZ » Wed Apr 17, 2013 6:05 am
I did for awhile. 3.73s were not great n 4.10s are better but I wish I had lower.
by JorDaneeKey » Wed Apr 17, 2013 8:07 am
HARDTRAILZ wrote:I did for awhile. 3.73s were not great n 4.10s are better but I wish I had lower.
Can you be more specific? What didn't you like? What will the 4.56 do for you?
JorDaneeKey
by HARDTRAILZ » Wed Apr 17, 2013 8:17 am
If gearing was lower it would help keep the trans locked up during interstate driving. Anything over 65 n it still wants to drop lockup which heats the trans and hurts mpg.
by JorDaneeKey » Wed Apr 17, 2013 8:19 am
Even with 4.10s? That's not encouraging.
JorDaneeKey
by HARDTRAILZ » Wed Apr 17, 2013 8:31 am
Nope. If I had choice n funds and they were available I would look at 5.13
by JorDaneeKey » Wed Apr 17, 2013 8:32 am
Guess we'll have to rethink our approach to how we want to re-gear.
JorDaneeKey
by HARDTRAILZ » Wed Apr 17, 2013 8:38 am
At 60 I was seeing 18-21 mpg with the lower profile roof rack this weekend. Anything up top really affects these trucks. My highway experience was improved by the lower drag as well. Just something to think about with all y'all are doing.
by navigator » Wed Apr 17, 2013 9:06 am
I've recently added Dirty Anton, Regulator and corrected MikeKey's as well.
I'll add Ben once I get a little more info from him.
by mikekey » Wed Apr 17, 2013 9:17 am
Thanks Chris.
:hijack:
My wife forgot that our MPG's we measured are not accurate because of the difference in tire size, the same way the speedometer is off. The odometer is reporting as though we traveld a shorter distance. The car was telling us we where getting 10MPG but I believe that number to be closer to 14~15 MPG.
We haven't had problems with the transmission staying locked up, but that could have a lot to do with our rebuild. She stayed locked at 70mph during our trip with a heavy roof rack. The rack does seem to effect these vehicles to some degree.
I'm on the hunt for an SS rear end. The question right now is which lower gear set will be the best combo for long haul road trips and off road. I need something decent for FL to Utah and not just decent for hill climbs over rocks. :cheers:
by JorDaneeKey » Wed Apr 17, 2013 9:21 am
Just noticing that with the increase in temps here over the last few days that to stay locked up I need to travel a bit slower, which causes traffic issues. Yesterday was all but impossible to stay locked up over 50 mph, but that was with 90+ temps and a strong crosswind.
JorDaneeKey
by darring70 » Wed Apr 17, 2013 10:40 am
mikekey wrote:I'm on the hunt for an SS rear end. The question right now is which lower gear set will be the best combo for long haul road trips and off road. I need something decent for FL to Utah and not just decent for hill climbs over rocks. :cheers:
If you swap the rear end for a ss then what would you use on the front if you have a 4WD, as far as I know SS models are only 2WD, correct me if I am wrong
darring70
by Cable810 » Wed Apr 17, 2013 10:45 am
Think they are AWD but I could be wrong. I think Kyle just swaped the front diff with the SS front diff. You shouldn't lose 4wd cause your not having to mess with those specific parts thats what I'd assume. Cause all TB and Envoys use the same front diff no matter 4wd or 2wd.
by darring70 » Wed Apr 17, 2013 11:06 am
Cable810 wrote:Think they are AWD but I could be wrong. I think Kyle just swaped the front diff with the SS front diff. You shouldn't lose 4wd cause your not having to mess with those specific parts thats what I'd assume. Cause all TB and Envoys use the same front diff no matter 4wd or 2wd.
You are right, I was wrong, I did my re-search and also called my friend who owns a SS and it is AWD
darring70
by navigator » Wed Apr 17, 2013 11:18 am
if you swap a SS rear with 4.10 gears, you usually have to re-gear the front or swap in a 4.10 front diff.
by dvanbramer88 » Wed Apr 17, 2013 11:29 am
Cable810 wrote: Cause all TB and Envoys use the same front diff no matter 4wd or 2wd.
Why would a 2WD truck have a front differential? :slap:
Some TBSS are AWD and some are regular 2WD. The AWD was an option.
The only difference between a 4WD and an AWD on these trucks is the transfer case. NP4 and NP8.
by Cable810 » Wed Apr 17, 2013 12:28 pm
dvanbramer88 wrote:Why would a 2WD truck have a front differential? :slap:
I needed that slap :lol:
by mikekey » Wed Apr 17, 2013 2:49 pm
I think it's well established you have to regear the front. I'm just looking for what I can find at a good price with low mileage, I may regrear both front and rear since 4.10's are the lowest gear to come from the factory. If I chose to go with 4.56 or something.
by Opeth » Wed Apr 17, 2013 10:39 pm
navigator wrote:I've recently added Dirty Anton, Regulator and corrected MikeKey's as well.
Haven't added me to the list, anything in particular you need info wise?
