SAS question, because we need more SAS.
by BrandonB » Thu Aug 10, 2017 1:55 pm
Can i get away with using stock drive shafts into a dana 60 and gm 14 bolt?
Thanks dudes.
BrandonB
by Diacom » Thu Aug 10, 2017 9:31 pm
If you find the appropriate u-joints I suppose you could.
But the length will be a problem after you figure out how to get them to mate to the axles. You'll have to have them lengthened and balanced anyways, might as well have the appropriate yolks put in place so you don't have such small caps on one end and larger on the other so to speak.
by HARDTRAILZ » Fri Aug 11, 2017 10:43 am
Not in stock form and driveshafts are pretty cheap in the whole equation of a SAS.
