WAAG Grill guard question
by Mirage » Fri Jan 16, 2015 8:28 pm
I just recently picked up a used WAAG 1 piece grill guard and my question is if there is supposed to be a bracket where it slides through the hole in the bumper cover to attach to the frame? When I slid the bottom part of the bar through the holes in the bumper I couldn't see where the holes on the bar line up with any corresponding holes in the frame.
Any pics, guidance, juju would be appreciated.!
Mirage
by Trail X » Sat Jan 17, 2015 9:11 am
Yes, there are brackets that bolt to the radiator mounts and the rest of the waag. There are also two brackets that mount above the bumper. Without those you're SOL.
by Mirage » Sat Jan 17, 2015 10:59 am
Thanks. I will have to call WAAG and see if I can get the lower ones. If not will have to make a set.
Mirage
Return to Off Road Discussion
