by v7guy » Wed Jan 14, 2015 9:15 pm
Frequently, yes, but occasionally the transfer case.
Sometimes as the disconnect wears and the bearings are going the gears and collar will be skewed and won't slide over each other because they're not inline. As everything wallows around sometimes they'll occasionally line back up. Sometimes it's also just lack of lubrication in the disconnect and it just needs disassembled, cleaned and lubed.
With the transfer case sometimes the motor that presses the clutches together isn't cycling properly. Generally it's not intermittent though.
If everything is working again and you can't get it to not work again I'd probably disassemble the disconnect and lube it up if it's never been done before. If you have access to a welder a few guys have had luck welding the gears and collar permanently engaged. It's a cheap duplicate of the AWD sleeve and should in theory increase the life on the bearings in the disconnect.
build thread All things in moderation, including moderation.
