Front Tow Hooks
by Shdwdrgn » Fri Aug 22, 2014 5:51 pm
DirtyBacon04 wrote:*Nerd alert*
Even my phone and media center runs linux! :viking:
Shdwdrgn
Contributing Author
by v7guy » Fri Aug 22, 2014 6:04 pm
I'm having trouble imagining where you could possibly move them from the stock location
by TPuls » Fri Aug 22, 2014 6:04 pm
hahahahaha....well I know nothing about computers and don't care about them. I listen to Pandora and search for off road stuff
TPuls
by Shdwdrgn » Fri Aug 22, 2014 6:16 pm
When I got to use my front tow rings for the first time, I realized that larger rings would put less crimp in the tow strap, but otherwise the size and position don't seem to be too critical. If they are 2-3 feet apart and wide enough to get a 2" strap on them easily, I would think you are good to go. The only consideration I made for mine was keeping them right beside the frame for overall strength.
Shdwdrgn
Contributing Author
by TPuls » Fri Aug 22, 2014 9:11 pm
Replaced original back bolt that goes through impact bar and frame with ~1 1/2" longer bolt to accommodate tow hook. Then, I widened an existing hole on impact bar all the way trough the frame to drop in second bolt. Not shown here, but took cutting wheel and took roughly half inch square out of impact bar to fit a 19MM wrench inside to hold second bolt while I tighten nut on bottom.
TPuls
by v7guy » Sat Aug 23, 2014 8:26 am
From the pics and description I'd be comfortable with that.
by Trail X » Mon Aug 25, 2014 1:10 pm
The only thing I'd try to do is get more washers on that frontal bolt. Tight bolts don't do much if they aren't squeezing down on something, but I'll agree with Jason, it's probably fine.
The only problem with hooks that face down like that is that they like to lose grasp of the strap as soon as it's slack. They often come with little retainer clips to prevent that from happening, did yours not?
by TPuls » Tue Aug 26, 2014 8:11 pm
Yep, that's exactly what I did. I added another washer to the front one on each side so it was snug before I even started torqueing it down. I went back and forth whether to mount on top or on the bottom. But, I guess if I'm not happy it won't take much to switch them around.
Oh and these did not come with the retainer clips. This was really just a temporary mod so I had something for the next few trails runs we're doing this month. But, regardless, I still wanted to do it right. I'm hoping to have a new bumper put together after that.
TPuls
by ErikSS » Wed Aug 27, 2014 9:27 pm
Crap. I like Windows 8 AND Best Buy. haha
by Shdwdrgn » Thu Aug 28, 2014 12:02 am
ErikSS wrote:Crap. I like Windows 8 AND Best Buy. haha
That boy ain't right in the head! :wallbash:
Shdwdrgn
Contributing Author
Return to Off Road Discussion
