ORTB Recommended Carry Offroad Tools & Sizes List
by mikekey » Sun Feb 02, 2014 9:32 pm
When you head off road you want to be prepared for anything that could break on the vehicle. Part of being prepared for handling repairs is taking the appropriate tools with you whenever you drive off the pavement. With the help of the other guys in the SME group, we've come up with a "minimum" recommendation of tools that you should have on hand to handle common repairs. The list is designed to act as a basic guide, and your tool kit might be a little different based on vehicle modifications. We recommend that you start with a basic mechanic's tool kit and add to it.
BASIC RECOMMENDATIONS:
(size ranges to help you match a tool kit listed below)
    - Full Set of of wrenches
    - Full set of sockets
    - 1/2 ratchet wrench
    - 3/8 ratchet wrench
    - Various length extensions
    - Breaker bar or Pipe (3/8's breaker bar works on the accessory belt)
    - (Any of these or all if you prefer)
      -- Adjustable Wrench
      -- Crescent Wrench
      -- Channel Locks
      -- Vise Grips
    - #2 phillips screwdriver
    - Flat head screwdriver
    - Rubber Mallet
    - Hammer
    - BFH ( BIG F**ing HAMMER)
    - Multimeter
    - Tire Gauge
    - Pillers
    - Wire Stripper
    - Pry bar or crow bar
    - Chisel
RECOMMENDED SPECIALTY TOOLS:
    - Pitman Puller
    - Pickle Fork
    - Inner tie rod tool (??)
    - CV axle pulling tool w/ slide hammer
    - Tire Repair Kit
MISC ITEMS & TOOLS:
(Good Idea to have on hand)
    - 1 Roll of electrical tape
    - 1 Roll of Duct Tape
    - 28" HVAC zip tie (will fix a lot of problems temporarily.)
    - OBDII Code Reader
    - Super Siphon
    - Chain 4ft - (DirtyBacon - "Great for fan clutch fix") (Fishsticks "Used as a temp fix for broken motor mount")
    - Tire Plug Kit
DIY TOOLS & ITEMS USED BY MEMBERS:
HARDTRAILZ wrote:I keep a 18 or so inch piece of rebar inside my hi lift handle. Works great for CV removal.
Most Common Wrench & Socket Sizes:
    8mm - Battery connector
    10mm - Thermostat housing
    13mm
    14mm - Caliper bolts
    15mm - Oil Pan drain plug, Bolts around Disconnect, Alternator bolts
    17mm - Radflo top strut nuts
    18mm - Hub bolts, Caliper Bracket
    19mm - Lug nuts
    22mm - Tie Rod Castle Nut, LCA Castle Nut, Lower Control Arm Bolts, Upper Control Arm Bolts
    24mm - Strut mount to LCA bolt
    35mm deep socket (oem wheel hubs)
    36mm deep socket (oem wheel hubs & aftermarket)
    - Allen Hex Keys
      -- 2.5mm
      -- 6mm
      -- 10mm
    - Torx Keys
Moderators Note: We want to keep this discussion free of arguments about tool brands & free of recommending you just carry a big tool kit. The point is to create a list of specific tools that one is most likely to use. We do not want it turning into a thread recommending people carry diesel powered welders and 5000 piece aircraft mechanics tool kits.
Second note, please only respond with either a recommended tool you use regularly to be placed in one of the above categories on the list or if you know of a specific size that fits something on our rigs to add the size chart. Also, let us know if you have DIY tools like rebar on a handle that you have made yourself that you carry.
:flex dirty:
by Moots1288 » Sun Feb 02, 2014 10:27 pm
Linemans and or wire strippers
by mikekey » Sun Feb 02, 2014 10:34 pm
Moots1288 wrote:Linemans and or wire strippers
Updated :thumleft:
by HARDTRAILZ » Sun Feb 02, 2014 10:49 pm
by Moots1288 » Sun Feb 02, 2014 11:05 pm
:Iagree: Seen that at Tecore and went that route, Also had a 1" Black cap welded to the top of it and a 1" Female x Male Black coupling welded to the hilift handle for easy storage and for a flat surface to hit with a lump hammer.
by mikekey » Sun Feb 02, 2014 11:07 pm
I'm having a hard time picturing this. Think you guys could post a picture sometime?
by Moots1288 » Sun Feb 02, 2014 11:28 pm
Here.
by Jrgunn5150 » Fri Apr 24, 2015 1:31 pm
I just want to add, 7mm Hex wrench, or Allen wrench if you prefer. None of my set's came with that size, and it totally held me up from taking my sway bar end links off.
by HARDTRAILZ » Tue Apr 28, 2015 1:38 pm
I think Bacon had something in another thread about CV removal tools that applies.
DirtyBacon04 wrote:I tried something similar a few months ago. I used a ratchet strap, looped one end around the inner tripot, hooked other end to front d ring (used strut as a redirector for the strap to give it a relatively straight pull). Put some tension on it, tapped on the disco a few times with a small hammer and it popped right out.
Most do not think of a ratchet strap as a tool, but seems like a great idea for a trail fix!
by tarsh » Tue Apr 28, 2015 1:57 pm
Good idea, Haa I'll have to try that one
Take the path less traveled
tarsh
Name: Nathan Schroeder
